93 SC400 brake felt soft
Old 03-12-01, 07:35 AM
VQT
VQT's Avatar
Question
Hi,
I just got a 93 SC400 with traction control. The brake felt very musshy and I thought it is a simple air in the brake lines. After bleedling the brake system, it still feel soft. I have not seen any leaks from the master cylinder yet.
Is there any special procedure when you bleed the brake system with traction control?
I used the cup and hose type to bleed the system. As of now, the whole brake system fluid is new, yet the brake still feel soft.
What did I do wrong? Or is it the master cylinder is gone?
Old 03-14-01, 05:33 PM
mindflux
mindflux's Avatar
Default so many things to consider
If brakes are mushy first inspect the obvious...are the pads ok...if they are very wasted change them.
Bleed the system correctly usually rear first and then front. Also remember that there is an ABS unit with many hoses going in and out...all of those have to be free of air...they can actually have bubbles that will not come out on a regular bleeding procedure.
Inspect the master cylinder but usually is hard for it to be broken because what you'll get is a normal brake feel and then a fade.
Hope this helps.
Mind
Old 03-15-01, 05:13 AM
VQT
VQT's Avatar
Default Brake
Mindflux,
The pads are in good conditions; I did bleed the brake correctly (at least I think I did), right rear first then left front, left rear then right front. I did this twice, I know that all old fluid is out. I used Dot 3 fluid.
At least the traction control is working.
Is there a procedure to check/bleed the ABS and the traction brake lines?
I am still waiting for the service manual, but what can I check/do while waiting for it.
Old 03-15-01, 05:14 AM
gadgetSC
gadgetSC's Avatar
Lightbulb Another Suggestion
Just another suggestion. You might want to check your brake lines. I went throught the same thing with the feel of my brakes. It was suggested to me to replace my brake lines with Stainless Steel Lines. So I bought the set with The SupraTT Calipers. I have only installed the lines and It really did make a difference. MY car is a 92 and the lines were the originals. They say its possible for the old rubber lines can bulge under pressure.
Hope this helps!
durps
SC- 1st Gen (1992-2000)
06-01-12 05:17 PM
haroun
06-10-11 01:51 PM
Lexus082
Suspension and Brakes
15
10-17-07 03:39 PM
VQT
03-14-01 08:33 AM
Quick Reply: 93 SC400 brake felt soft
