vsc check burning after replacing wheel hub.
Old 08-05-16, 01:32 PM
charle5
charle5's Avatar
Default vsc check burning after replacing wheel hub.
Hello ,
After i changed a bad left front wheel bearing..
The vsc check ligt came up.
The ABS wiring should be ok.
Is it possible to reset the alarm without special tools i.e
to put a loop on the OBD-2 connecter.
Or should the alarm disapear if the system is ok ?
I know that there is a difference between right and left bearing(abs connection)
is250 model 2006
Old 08-06-16, 02:39 PM
charle5
charle5's Avatar
Hello ,
Solved the problem my self.
Impedance of new ABS coil was 620 ohm but not consequent.
The original was 1380 ohm.
Socket of after market caused isolation.
vsc alarm ,reset by putting a loop between point 4 and 13 of de OBD2 socket.
Starting again and i tried de "Toyota" way 5 times pushing the brake pedal within a few seconds.
VSC Alarm gone !!
Tomorrow il change the right wheel hub too,was also a little bit noisy !
LStyle
11-25-15 05:56 AM
MSGX470
GX - 1st Gen (2004-2009)
07-28-13 07:44 AM
msarahalex
12-31-12 08:21 PM
phenomic
09-21-10 03:06 PM
Quick Reply: vsc check burning after replacing wheel hub.
