06 IS350 transmission pan leak
Old 02-19-16, 08:18 PM
1bimmer
1bimmer's Avatar
Default 06 IS350 transmission pan leak
I see the transmission pan gasket leaking a little, not dripping at all. I went and check the bolts and some are pretty loose. Can i just re-tighten the bolts down and be done? please advise
Thanks
Old 02-19-16, 09:54 PM
isfdude
isfdude's Avatar
Try tightening them a little, not too tight though or you will squeeze out the gasket, if that doesn't help drop the pan and change the filter and use new World standard Toyota transmission fluid then use gray silicone and install the pan.
Old 02-20-16, 05:31 AM
1bimmer
1bimmer's Avatar
Ok thanks, i was trying to stop it for now till i have time to change it.
Old 02-20-16, 06:20 AM
1bimmer
1bimmer's Avatar
I dont have the specs or a torque wrench, i figure just go around and just firmly tighten the bolts down for now. Should help the seepage. Thanks
Old 02-20-16, 01:24 PM
isfdude
isfdude's Avatar
When it's leaking you don't need to use a specific torque For them, doing it firmly should be just fine.
Old 02-20-16, 06:06 PM
1bimmer
1bimmer's Avatar
Yes that all i did so far and so far so good. Thanks
Old 02-21-16, 10:03 PM
isfdude
isfdude's Avatar
Good, hopefully that will do the trick.
Old 02-22-16, 06:27 AM
1bimmer
1bimmer's Avatar
Yes hope so too. Thanks
Old 02-22-16, 06:31 AM
1bimmer
1bimmer's Avatar
I was wondering if it was common for this to happen? If so then so much for World Standard ATF lifetime fluid. Lol
If its common and you have to change gasket you might as well change the complete fluid while you doing it or bring to dealer to have it service.
Old 02-25-16, 10:19 AM
1bimmer
1bimmer's Avatar
Look like still seep a little, may have to change gasket. My buddy been driving his IS350 for years with seepage and said transmission still drive great. lol
1bimmer
06-29-22 08:52 AM
Cisco350
06-07-19 08:01 PM
lexslexus
22
03-14-17 10:23 PM
lysis250
09-23-16 12:52 PM
djl
SC- 1st Gen (1992-2000)
09-29-02 06:44 PM
Quick Reply: 06 IS350 transmission pan leak
