oil on spark plug
Old 07-14-14, 08:56 PM
mr3gs300
mr3gs300's Avatar
Default oil on spark plug
I finally got around to changing my spark plugs, when I took the first one out the one closest to the front on the passenger side I noticed there was some oil on the ignition coil tip and then when I pulled out the sparkplug it was covered in oil, this mustve happened on a couple of days earlier I was doing like about 80-90 mph when the check engine light and check vsc came on, what can be wrong to cause this?
Old 07-15-14, 06:19 AM
BDSL
BDSL's Avatar
For the oil on the spark plugs, you have to replace the valve cover gaskets.
Old 07-29-14, 07:52 AM
babyboygs
babyboygs's Avatar
Default oil on spark plugs
had same problem cahnged valve covers.. but make sure to check and possibly change spark plug wires!!! the boot that covers your spark plug also covers those holes just to the sides of the spark plugs! when you look in there and clean that oil you will see what i mean..
Deathrow23
11-14-23 03:11 PM
gebo
07-06-15 11:59 AM
mak89
Performance & Maintenance
40
05-08-15 08:19 AM
mak89
Maintenance
05-14-11 11:06 PM
plocke82
Maintenance
05-02-09 11:16 PM
Quick Reply: oil on spark plug
