2007 ES350 oil leak
Old 03-11-14, 10:43 PM
TLPLEXUS
TLPLEXUS's Avatar
Default 2007 ES350 oil leak
I have a 2007 Lexus ES350. I peaked under my car recently and noticed a bit of oil underneath one of my boots in the passenger side (oil leak #1 in the attachment). There is also small slight oil leak coming from below the serpentine belt (oil leak #2 in the attachment).
In regard to the oil leak #1 in the boot, is that a rack and pinion or the right axle? Is the boot repairable or do I need to replace the whole shaft?
Not sure about oil leak #2 from behind the engine. Anyone know what it is?
File Type: pdf
Old 03-12-14, 11:23 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Both appear to be due to a leaking CV axle boot clamp.. on the inner boot. You can see grease flung around on the sway bar and where your #1 arrow is pointing. If the grease got onto the power steering rack boot, which is what that is, and look like a leak. Its also possible that you have a leaking power steering rack. It would be best to get the car on a rack, so you can inspect further, clean up the mess, and monitor the leaks.
Old 03-13-14, 07:04 AM
1000hp
1000hp's Avatar
The rack & pinion is definitely leaking. Common problem.
The fluid near the CV boot could also be oil leaking from the timing cover seal. That's also quite common.
Old 03-14-14, 06:19 PM
burny
burny's Avatar
I thought the 07's had electronic steering, not hydraukic
Old 03-22-14, 12:00 AM
TLPLEXUS
TLPLEXUS's Avatar
Thanks guys for looking into this. If the rack and pinion is causing the issue, does that explain why when I am going 70-80mph downhill my steering wheel would shake?
Is this a big job to replace the rack and pinion or is it fixable?
Old 03-22-14, 12:01 AM
TLPLEXUS
TLPLEXUS's Avatar
I think mine has hydraulic since I have power steering fluid here. It doesn't seem to be leaking from that though.
Carlsbad
ES - 5th Gen (2007-2012)
06-28-17 11:20 PM
UGAALF
10-03-15 03:16 PM
dbui
RX - 1st Gen (1999-2003)
04-22-14 12:35 PM
2jznosht
Performance & Maintenance
05-16-12 07:54 PM
Quick Reply: 2007 ES350 oil leak
