es300 cel help
es300 cel help
I have a 1999 lexus es300 and i am throwing a few codes out can anyone help p1135 p1155 p1351 a random misfire code and a 2 4 6 misfire codes any help would be great
Maintenance Moderator
I guess cleaning the oil control valve screen would be a better first step, I just remembered that code can be set by a non functioning vvti solenoid...
Basically, find the vvti actuator, pull the banjo bolt that goes into it, inside is a cone shaped screen, remove, clean with brake clean/carb cleaner, reinstall... There are two on your motor, just do both while you are at it...
I tried the cleaning to no avail and replaced both sensors same code still comes up but only after the p1135 and the p1155 come up ig. Clear the codes those come back immediately
