Need Aftermarket Keyless Entry!
'96 ES300. I want to add an aftermarket keyless entry system. Has anyone installed this and can you give me some pointers? I assume you go to the drivers side door for the connections and then to the ignition and ground etc. The kit I purchased was about $50.00 and with a small accessory relay the trunk should be able to be opened as well. I am guessing that that hookup is also in the drivers door.
Any help is greatly appreciated...
Don
Don
b1gredek
01-21-06 08:54 AM
