99 RX won't shift into park - can't start -- Help!!
Old 01-01-14, 11:18 AM
craigj2445
craigj2445's Avatar
Default 99 RX won't shift into park - can't start -- Help!!
Problem started by shifter not engaging into D position and D light on dash not lighting although all others lit fine when shifter was in their positions. Had to put shifter in 2 then slide up to D to get in D-drive position. Now cannot get into P position to start car - it clicks but it's not really in P because car can move. So now it's not starting because can't get in P. I can move shifter by pressing auto lock release button -- but I don't think it's really in P-park anyway since wheels move freely. Brake lights work fine. Drives and shifts fine - when I can start it. It seems like a progressive mechanical problem -- any ideas?
Battery is charged
visually checked fuses under hood - all okay; the D - drive light not lighting on dash bothers me though??
I'm new to this forum - so I hope someone can guide me to a cause or solution.
Thank You!
Old 01-01-14, 01:56 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Pretty common for the "D" light bulb to burn out, since its the most used light. I wouldnt worry as much about that as the shifting concern.
Try starting the car in "N"... the car should crank over in both the "P" and "N" position. If it works in "N", then id say you may have a cable adjustment problem, or something wrong with the position switch.
Old 01-01-14, 04:01 PM
craigj2445
craigj2445's Avatar
Tried to start it in nuetral several times but will not start there either. Could it be the solenoid?? It's in park but not really since car can roll freely (right onto tow truck tomorrow morning)! Thank you very much for your response.
steveis350
06-20-19 10:44 PM
User 8822
08-09-16 05:44 PM
craigj2445
RX - 1st Gen (1999-2003)
02-10-14 08:11 PM
LSmith
06-15-11 01:03 PM
vcool21
IS - 1st Gen (2001-2005)
12-07-04 02:02 PM
Quick Reply: 99 RX won't shift into park - can't start -- Help!!
