SC300 OBD1 Check Engine Issues
Old 06-09-12, 06:13 PM
Piratse
Piratse's Avatar
Default SC300 OBD1 Check Engine Issues
Hi everyone,
I did a search and found nothing to explain this. I have a check engine light on (1993 lexus sc300). I ran 2 cables in the diagnostic fuse box TE1 and E1 to check the codes. Problem is it just keeps flashing on dash. No specific flashing just a constant flash with no long pauses. I watched it for several minutes and it just flashes non stop(similar to a blinker flash). Any idea what the problem is (or is this in itself a code)? Thanks!
Old 06-09-12, 09:18 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
constant flash means that no codes are stored...
disconnect the battery to reset the light and continue driving, see if it comes back...
Old 06-09-12, 09:34 PM
Piratse
Piratse's Avatar
You are helping me out left and right tonight! Thanks for the tip I'll give it a shot tomorrow.
Old 07-16-12, 02:28 PM
Piratse
Piratse's Avatar
In case this comes up in searches for the future. The problem was a bad ECU. Sent it to a repair place. It still had a check engine code but it now flashes the correct codes.
Old 07-17-12, 08:17 PM
mitsuguy
mitsuguy's Avatar
Good to know... Thanks for the heads up!
Old 07-17-12, 08:36 PM
GS4_Fiend
GS4_Fiend's Avatar
What problems were you experiencing prior? On these cars OBD 1 constantly flashing is completely NORMAL.
Old 09-13-13, 08:44 PM
skeletor
skeletor's Avatar
Sorry for an old bump but I was always under the impression a constant flash is "system pass"
socal300
Performance & Maintenance
07-07-12 11:28 AM
socal300
05-06-08 08:13 PM
GOLDSc300
Maintenance
04-15-07 07:32 AM
Pepsiguru
GS - 1st Gen (1993-1997)
05-23-06 11:03 PM
sc300jon
SC- 1st Gen (1992-2000)
10-15-01 11:44 AM
Quick Reply: SC300 OBD1 Check Engine Issues
