Technical Help (by Mitsuguy and ArmyofOne)
Old 12-17-12, 04:50 PM
  #256
sgmbab
sgmbab's Avatar
Default bad water pump?
So I have a 2007 IS250 and recently got my water pump replaced at the dealership. Every now and then i would some coolant around the top of the reservoir near the cap area. I would clean it up only to find it again after a few days. My question is this normal and do you guys know what it could be?
Old 12-18-12, 03:33 PM
  #257
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Probably just needs a new cap... the tend to wear out and they stay sealed so long as they aren't opened - when they are opened, which it obviously was, the rubber seal deteriorates more...
$10-$15, any auto parts store... not necessary for an OEM part...
Old 01-13-13, 12:36 PM
  #258
xeff
xeff's Avatar
Default Parts Identification rx450h
Can someone please identify what part this is.
The peice has a cracked in it and also the hose "blue liquid leaking?" This is located at the front left bumber, next to the left fog light. Autobody shop called it a "Transmission Oil Pump"....but i wouldn't know what it really is.
2010 Lexus RX450h, thank you in advance.
Old 01-15-13, 04:18 PM
  #259
Cartune
Cartune's Avatar
Mitsuguy, for cel code p0441 and p0446. What would be the common issue and how to fix it? I change a new gas cap and check for loose hoose, found none.. What else should I do? Thank you in advance
Old 01-15-13, 04:56 PM
  #260
mitsuguy
mitsuguy's Avatar
picture of location in vehicle? or just a picture showing more of it and the hoses to and from?
Old 01-15-13, 04:57 PM
  #261
mitsuguy
mitsuguy's Avatar
Usually has to do with the vacuum solenoid valves... replacement of said valves is the only fix, generally...
Old 01-15-13, 05:25 PM
  #262
Cartune
Cartune's Avatar
Where is that located? Got a part number? Thx
Old 01-15-13, 08:32 PM
  #263
Cartune
Cartune's Avatar
is it this? part# 77740N
Attached Thumbnails Technical Help (by Mitsuguy and ArmyofOne)-770406.jpeg   Technical Help (by Mitsuguy and ArmyofOne)-screen-shot-2013-01-15-at-11.29.41-pm.png
Old 01-21-13, 08:35 AM
  #264
xeff
xeff's Avatar
That's a picture if it taken by the auto body shop when the front bumber was removed. It's located right behind the left fog Light location.
Old 01-21-13, 07:20 PM
  #265
mitsuguy
mitsuguy's Avatar
its not the windshield washer pump is it?
Old 01-21-13, 08:27 PM
  #266
Cartune
Cartune's Avatar
Mitsuguy, can you help answer my situation
Old 02-04-13, 05:58 PM
  #267
shoulin
shoulin's Avatar
How do you get to the fuel injectors on an 01 gs430?
Old 02-04-13, 06:01 PM
  #268
shoulin
shoulin's Avatar
I am having trouble getting to the fuel rail on the drver-side.the vehicle is a 2001 gs430.
Old 02-04-13, 07:44 PM
  #269
mitsuguy
mitsuguy's Avatar
not sure the problem? I mean, they aren't super easy to get to, but everything in the way has to come out...
Old 02-05-13, 05:02 PM
  #270
shoulin
shoulin's Avatar
In reference to the fuel rail, how do you depressurize the fuel or do you just open the cap? Sorry but its my first time doing Injectors.
Quick Reply: Technical Help (by Mitsuguy and ArmyofOne)
