OK to change from Synthetic to Conventional Oil?
Old 11-29-10, 07:38 PM
OceanView
OceanView's Avatar
Default OK to change from Synthetic to Conventional Oil?
My 98 ES300 is leaking a bit more than usual.
I put in Synthetic at about 70K was ok til about 150K.
I wanted to put in conventional oil in hopes to slow/stop the leak til next year but wasn't sure if this could be a problem on the 1MZ-FE engine.
Thoughts?
Old 11-29-10, 09:10 PM
WAES300
WAES300's Avatar
From what I understand, if an engine leaks, it'll leak regardless of whether the oil is synthetic or not. Though I've also read the total opposite..
Old 11-29-10, 10:50 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Its going to leak either way... so its not going to matter. I would investigate and fix the leaks.
Old 12-02-10, 11:40 PM
gemigniani
gemigniani's Avatar
A 10W-40 "High Mileage" Conventional oil will definately slow the leak for many years and miles. I know this from owning several vintage Toyotas. Most major oil companies sell "high mileage" types of conventional oil; e.g. Valvoline Maxlife, Pennzoil High Mileage, Castrol High Mileage and so forth.
Old 12-03-10, 11:51 AM
OceanView
OceanView's Avatar
Hope you're right.
I just changed over to Valvoline Maxlife Synthetic Blend 10W40.
I was running low on oil and didn't want to just add oil.
Will report back my findings after putting some miles on the car and see if I notice any change.
Old 12-03-10, 11:54 AM
jadu
live.love.laugh.lexus
jadu's Avatar
i switched from synthetic to regular oil on the mazda 50k miles ago.. engine has been fine
Old 12-04-10, 03:55 PM
PlatES300
PlatES300's Avatar
changing oils won't fix the leak. When was the last time you changed the front and rear main seals? The rear one is usually the culprit as you can't see it. I would definitely look at that first. I've had 3 ES300's and it was always the rear main seal on 2 of them. I changed it out on every car after 100k miles when I did the tune up since everything was already out. You should also change out the intake plenum gasket as well since you have to take that out to get to the rear main seal.
Old 12-04-10, 10:26 PM
OceanView
OceanView's Avatar
thanks for the info, I am planning on opening up the engine and checking/replacing any leaking seals & gaskets sometime later next year.
Still investigating what to do as I've never done anything like this in the past.
Is this a fairly doable project for a weekend mechanic?
Old 12-05-10, 03:43 PM
PlatES300
PlatES300's Avatar
Not exactly an easy task because you have to take apart a lot of hoses and things, but if you take youre time, it shouldn't be too hard. If you're in doubt, then it's better to have a mechanic friend or someone who knows what they're doing there just in case. It took me about 2-3 hours to take everything out, clean it, and replace all the seals. Good luck with it.
SeanO
09-26-21 02:44 PM
Eurofreak
IS F (2008-2014)
33
03-19-18 02:40 PM
tomf
12
01-10-11 09:06 AM
MATEOGS
08-12-08 07:14 PM
stock300
Maintenance
14
01-07-03 05:00 PM
Quick Reply: OK to change from Synthetic to Conventional Oil?
