This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Special Interest Forums > Maintenance
Thread Tools Display Modes
Old 09-21-09, 11:23 AM   #1
Evanscd
Trader Score: (0)
Default Sc400 won't start
Ok, I have a strange one. I have a 93 SC400. It won't start, but even stranger every time I try to start it. The doors lock. When I turn the key back to off the doors unlock.. Other than a faint click from under the hood, this is all that happens. I'm thinking something with the theft deterrent system? But I can't seem to find a similar problem anywhere on the web. I really don't want to have to take it to Lexus and pay 500.00 if it's something stupid. Also if it matters, the battery was very dead just before this started happening. (I have since replaced it.) Thanks to anyone that can give me some ideas.
Evanscd is offline   Reply With Quote
Old 09-21-09, 11:39 AM   #2
masagsxr
Trader Score: (0)
masagsxr's Avatar
Seems like it does have something to do with the alarm. I had an aftermarket alarm back in the days (different car) and this is the exact same thing that happens..... Do you have an aftermarket alarm installed? Have you tried disabling the alarm at all before turning the key to start the motor?
__________________
98 LS400 Calipers, Drilled/Slotted R1Concept Rotors, Techna-fit SS Brake Lines.
Future upgrades: Better suspension (Silk Roads w/air cup)
masagsxr is offline   Reply With Quote
Old 09-22-09, 05:02 PM   #3
AshburnM3
Trader Score: (0)
before you take/tow it to the dealership, start from the basic first!!!
---> check/test your battery! can you jump start your car?
AshburnM3 is offline   Reply With Quote
Old 09-24-09, 04:18 PM   #4
Evanscd
Trader Score: (0)
No, I have a new battery in it and even when hooked up to jumper cables from my truck it won't start. does the exact same thing.
Old 09-24-09, 07:26 PM   #5
AshburnM3
Trader Score: (0)
check your starter next but i hope the starter is not under the intake--> sc400
good luck
Old 09-30-09, 11:24 AM   #6
pineview36
Trader Score: (0)
I have a 95 Lexus SC400, and at first my freeze plug went out and it leaked water into my starter so I replaced both and it was running good, but after a couple days it started jerking real bad when I tried to give it gas and now it wont crank right. If I try to crank it at first it will start up with no problem and then I can turn it right off and it wont crank for another 5 hours, please let me know if anyone has an idea of why this is happening
pineview36 is offline   Reply With Quote
Old 10-17-09, 09:27 PM   #7
GS4_Fiend
Trader Score: (1)
GS4_Fiend's Avatar
sounds like a starter problem if doesnt cranks and you only hear one click
GS4_Fiend is online now   Reply With Quote
Tags
alarm, battery, crank, dont, key, lexus, long, sc400, security, start, starter, system, turn, turned, wont
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
