99gs400 left key on and now wont start
Hi guys I need some help. I was cleaning my car last month and left the ignition key on. When I went to start it the battery was dead. I recharged it and it spun but would not start. I checked all the fuses and everything looked good. I remember my Supra has an igniter that will burn out if you leave the key on. Does anyone have any info on testing?
I really want to get the car running it has been sitting for over a month. I was going to keep it but now I am just going to paint it and sell it. I have too many cars and now with a baby I just can't keep it, no time. I put a rebuilt motor in my supra and the new fuel pump quit and haven’t Evan touched it. I have way too many projects. I am actually disappointed I waited this long to work on it. I might need to drain the gas in the tank it is a couple months old. Before this the car ran perfect, Ice cold air and all. I just got my wife a new car and was going to keep it as a 3rd but I don’t even have the time. So any help is appreciated...
Thanks,
Eric
Thanks,
Eric
Maintenance Moderator
if it turns over (quickly), but doesn't start, then you are missing something... key elements to a vehicle starting are fuel, spark, and air (compressed)... check for spark by pulling a spark plug boot while someone tries to start the car - careful not to shock yourself... if you have spark, need to check fuel... this is harder to check for, but can be done numerous ways... if you don't have a way to hook up a fuel pressure gauge, then I would find the fuel line where it runs into the fuel rail... cycle the key a few times, then undo the fuel line from the fuel rail - it should spray fuel with some pressure (careful with this, it will be flammable) - this will give you a general idea if the pump is making pressure or not...
I was able to spend a little time on it before it got cold. I have a signal so spark is good. My battery is new and I tried it with my jumper on. With spark and it spinning like it is not even trying to fire I figured my fuel is bad. I sprayed some starter fluid down the intake and it started and ran real rough for a sec. Well I want to get all the fuel out. I could not shove a hose down the tank. I guess something blocking maybe a screen. So I disconnected the fuel line to the manifold and turn the key on and some nasty gas came out for a couple secs while the fuel pump ran. I need to try and trace the wire to the fuel pump or relay and see if I can manually keep the pump on to empty the tank. I forgot I have my friends OBDC Code reader I borrowed to fix my neighbors van. I tested and no codes came. I just hope my pump and injectors still work fine, and its not a pain to change the fuel filter. I have a few questions
1. Anyone know where to download the dealer manual online for free
2. Does any know know what wire I can jump to keep the pump running.
3. Are there any links to fuel filter removal. I heard my fuel filter is in tank and I have to remove the tank to get to it. Any info appreciated...
Thanks everyone for your help..
crddfltswp
GX - 1st Gen (2004-2009)
07-19-19 03:56 PM
Axvel
08-20-07 03:55 AM
