SC400 Heater control valve?
Old 11-03-08, 08:35 PM
dirkdiggle
dirkdiggle's Avatar
Default SC400 Heater control valve?
My heater control valve doesnt seem to be working for some reason.
If I swap the air lines on the control valve, the suction opens up the valve all the way and allows me to have heat.
What specific thing on this part actually fails??.....it all works off suction doesnt it??
Old 11-04-08, 01:51 PM
dirkdiggle
dirkdiggle's Avatar
anyone know what part fails?? The electrical.....the suction thing???
Old 11-04-08, 02:59 PM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
My solenoid has gone out a few times, I've swapped it before, and finally found one that works. Check your local junkyards. I actually found a replacement that was the EXACT same as the SC400 one from a Q45. GL.
Old 11-04-08, 04:56 PM
dirkdiggle
dirkdiggle's Avatar
What part is the solenoid??
From what I see, these are the parts:
1.) The coolant valve that lets the water flow thru
2.) the round thing the pulls the little arm open or closed.
3.) the part where the electrical wires go into.
What are the real names for the 3 parts I mentioned??
Old 11-04-08, 05:05 PM
Jewcano
Jewcano's Avatar
The solenoid is the part ontop with the round small plastic piece. Thats the solenoid. The big metal thing is the valve. The valve on mine also locked up before, but I picked up an aftermarket one from a local parts store.
Old 11-04-08, 05:46 PM
dirkdiggle
dirkdiggle's Avatar
Thanks!
My valve opens and closes just fine if I reverse the hoses so I think that is fine. It must be the solenoid that failed!
Old 11-04-08, 07:16 PM
Jewcano
Jewcano's Avatar
Check the solenoid. If its dead, its an easy swap to fix it.
mbz560
04-08-13 12:03 PM
BlaineyB
Performance & Maintenance
03-15-12 10:35 PM
Quick Reply: SC400 Heater control valve?
