How to shut off "Oil Maint Reqd" warning light
I have a 2007 ES350 and just had the oil changed at a non Lexus shop. How do you shut off the "Oil Maint Req's" warning light that is in the center of the dash? I have looked all through the manual and can not find the answer.
My wife has an Acura MDX and they put instructions in their manual on how to shut off the warning light.
Turn on the ignition to make sure its on odometer. Turn it off. PRESS AND HOLD THE RESET BUTTON for the odometer. THEN TURN ON THE IGNITION THEN YOU SHOULD SEE THE ODOMETER READS IN DASHES. HOLD THE BUTTON TILL THE ODOMETER READS MILEAGE. ****** DON'T TURN ON THE ENGINE... JUST IGNITION ON. ********** The should be off after you've done this.
