08 RX350 DIY Coolant Drain & Fill?
Hi everyone. I haven't been able to find any information on ther interent regarding a drain and fill for a RX350. If anyone can help me out with a link, pictures or just some simple directions it would be appreciated.
I was just under the impression that it should be changed every 30K even with these "long life coolant." I don't really mind doing a drain and fill for the coolant since it's usually pretty easy job at least for Honda and Nissan products. But from what I've been reading....I should wait until at least 90K (to be on the conservative side) for the coolant "flush" and transmission "drain and fill." Is that the typical maintenance intervals for these two?
BTW, the car has 37K.
Maintenance Moderator
You can do it as often as you like, but I'd wait til minimum 50K... The Lexus coolants really do last 100k unlike the GM dexcool stuff which is crap...
And I'll be honest, the easy way is to have a shop do it, but if you are dead set on doing it yourself, just buy a can of radiator flush and follow the directions... typically, I would drain the radiator using the drain plug at the bottom, refill with water and flush chemical, let it warm up and run for a while with the heater on, then I take the thermostat out, disconnect the upper radiator hose, flush and drain everything, then refill with your choice of coolant...
