Go Back   Club Lexus Forums > Lexus Special Interest Forums > Maintenance
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read GarageUsed CarsVendors TSBs & Recalls
Welcome to Club Lexus!
Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
Thread Tools Search this Thread Display Modes
Old 09-09-08, 05:31 PM   #1
dirkdiggle
Garage is empty, add now
Trader Score: (1)
dirkdiggle's Avatar
Default 92 SC400 Suspension problem?
Car is a 1992 Lexus Sc400 with 160k miles.
My rear suspension has been making noise for a month and its getting worse as time goes on!
Pretty much it is a loud Hollow Clunk noise everytime I hit a bump going 10 mph +.
I have tested the rear suspension by pushing down on each side and it seems to rebound back to normal right away.
Does this sound like worn Struts/shocks or something else??
I have looked under the car and everything seems tight...no loose sway bar or anything.
How hard is it to replace the rear struts?? I looked on here and some say it is super hard while others say its very simple!!
Do I have to remove the rear seat to get at the bolts on top of the strut??
Thanks
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
dirkdiggle is offline   Reply With Quote
Old 09-09-08, 05:39 PM   #2
TheMole
Trader Score: (12)
TheMole's Avatar
Send a message via AIM to TheMole
Look into the wheel bearings, endlinks, or bushings in the rear.
You do not have to remove the rear seat to access the strut tower bolts. Just pull back the trim in the trunk and you should see them.
__________________
Electronic Dance Music Thread
05 Scion XB
99 Accord Coupe 5 speed - Sold on 3/28/2012
93 Black Onyx JZS147 - Sold on 9/12/2012
93 Diamond White Pearl JZZ31 - RIP on 09/02/2009
TheMole is offline   Reply With Quote
Old 09-09-08, 06:22 PM   #3
TheMole
Trader Score: (12)
TheMole's Avatar
Also, found a service bulletin that may help you out:
Rear Suspension - Clunking/Rattling Noise
SUSPENSION
SU95-005
OCTOBER 20, 1995
SC 300/400
Title: REAR SUSPENSION NOISE
Click the image to open in full size.
The rear spring bumper has been changed in production on 1995 SC 300/400 in an effort to reduce clunking/rattling noises.
SERVICE HINT:
A similar clunking/rattling type noise can be generated by an improperly torqued center support nut (27 N-m, 280 kgf.cm, 20 ft-lbs).
PRODUCTION EFFECTIVE:
Starting VINs:
JT8UZ30C*S0047966
JT8JZ31C*S0030524
Old Part Numbers: 48341-24040, 48341-24070
New Part Number: 48341-24071
__________________
05 Scion XB
Old 09-09-08, 06:31 PM   #4
dirkdiggle
Trader Score: (1)
dirkdiggle's Avatar
Here is a picture
Old 09-10-08, 08:02 AM   #5
mitsuguy
Maintenance Moderator
2000 Isuzu VehiCROSS
My Garage
Trader Score: (1)
mitsuguy's Avatar
just because it looks tight, doesn't mean it is...
jack up the rear of the vehicle, one side at a time (unless you have a lift)...
get the wheel of the ground, then grab the bottom of the tire and the top of the tire and try to push the top while pulling the bottom, then alternate pushing the bottom while pulling the top - what you are doing is feeling for any movement - you shouldn't be able to feel anything - it might not move a lot, but what we are looking for is a slight clunk -maybe no more than a 1/4", but it will most likely feel noticeably loose...
after push/pull up and down, do it side to side, looking for the same thing - it also helps to have someone watch the bushings and ball joints to look for movement as sometimes it may be hard to feel - grabbing a control arm or ball joint while you are pushing/pulling can be helpful in feeling smaller amounts of play somewhere...
obviously, do this with both sides - more than likely you have one or more of 14 total bushings in the rear that is loose, or one of (either 2 or 4, I can't remember) ball joints that is loose... also, while underneath there, you want to look for any rear subframe bushings that might be loose and also the bushings that hold the rear differential in place...
__________________
-cody: maintenance forum moderator
- Bridgestone/Firestone, Michelin/BFGoodrich certified
- ASE certified, Motor Vehicle Inspector, HVAC Licensed
- Lots more certs, too many to list here!
2001 Lexus IS300 GTE/Turbo/AEM Auburn Sky Pearl (1 of 1348)
2000 Isuzu VehiCross Kaiser Silver Metallic (1 of 544)
1999 Isuzu VehiCross Astral Silver Metallic (1 of 1021)
mitsuguy is offline   Reply With Quote
Old 09-10-08, 08:04 AM   #6
mitsuguy
My Garage
Trader Score: (1)
mitsuguy's Avatar
On a scale of 1-10, 10 being hardest, to replace rear shocks, I would say it's somewhere around a 4 or 5...
Unless replacing with aftermarket coils, you will need a spring compressor, then you will also need a big pry bar, all the rest of the tools are common sockets and wrenches... I did all 4 in my driveway in about an hour and a half, maybe 2 hours...
__________________
Old 09-10-08, 01:24 PM   #7
dirkdiggle
Trader Score: (1)
dirkdiggle's Avatar
I did the test you recommended and I do not have any movement when I push and pull the tires......does that mean that it is most likely my shock that is bad?? I dont think they have ever been replaced and the car has 160k miles!
which brand shock do you recommend...Monroe Sensa-Trac Strut or GABRIEL ??
Old 09-10-08, 05:52 PM   #8
mitsuguy
My Garage
Trader Score: (1)
mitsuguy's Avatar
Look into KYB's as well, but any of the above are just fine...
__________________
Old 09-13-08, 10:16 AM   #9
t70 supra
1995 Lexus SC
Trader Score: (-4)
just_blow_me
Send a message via Yahoo to t70 supra
hey im in milwaukee ill help u
t70 supra is offline   Reply With Quote
Tags
400, 92, bushing, common, lexus, loose, noise, problems, rear, replace, sc, sc400, shocks, subframe, suspension
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Service | JOBS
Get all contact info
Content Relevant URLs by vBSEO 3.5.2
