Sc300 oil leak problem
hey guys ok my car has a small leak so i asked a mechanic to look at it while i had some other things checked up on so he calls and tells me that it is a leak from the valve gasket? and that it is leaking into the sparkplugs and filling it up and than spilling out that is what is leaking. so is this possible and he says it is a very expensive job. i dont know if i should believe him or not because i didnt really look into the leak before i let him check it out. i just told him to hold off on the job. any advice?
Ask him what the cost would be.
alright thanks guys! how much do u guys think this job costs as a diy? time wise and moneywise?
nvm...i found the older threads seems kinda hard
like 30 for vcg and 40 for oem plugs and about 8 hours of youre time, its pretty straight foward but just be carefull when removing the 2 bolts under the y intake, its the hardest part, you might want to remove the intake behind the y so that its loose enough to wiggle everything around it will make life a lot easier
dubstatus
GS - 1st Gen (1993-1997)
12-07-16 07:27 PM
