what do you do with your old oil after you change it yourself?
Old 08-14-08, 07:06 PM
bagwell
bagwell's Avatar
Default what do you do with your old oil after you change it yourself?
recycle hopefully......but where???
does WALMART, AUTOZONE, etc accept it no questions asked????
Old 08-14-08, 07:12 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
required by law to accept it if I'm not mistaken...
Old 08-14-08, 09:13 PM
GSteg
GSteg's Avatar
I recycle it at my local recycling center.
Old 08-14-08, 10:31 PM
Trexus
Trexus's Avatar
I take my old oil to Goodyear or Kragen Auto parts...
Old 08-15-08, 03:14 AM
Spyder78
Spyder78's Avatar
autozone or strauss.
Old 08-15-08, 06:23 AM
KayGee
KayGee's Avatar
How do you transport it without a risk of spilling it everywhere? Sounds like too much trouble for too little savings for me.
Old 08-15-08, 09:04 AM
BDSL
BDSL's Avatar
You put the "old" oil into the bottle of the "new" oil. It is so simple.
Old 08-15-08, 01:12 PM
pingu
pingu's Avatar
I recycle it down the drain. j/k
Make sure you recycle your oil filter too.
Old 08-15-08, 02:55 PM
darkdream
darkdream's Avatar
Bottle it up place it in 3 garage bags just in case it leaks
Old 08-15-08, 09:20 PM
T0ked
T0ked's Avatar
I return it to my local autoparts store. They have a bin out back where they collect used oil. Pour the old oil into the bottles the new oil came in. As above, I have a large garbage bag I use specifically for the oil return.
Old 08-15-08, 09:31 PM
93sc3005sp
93sc3005sp's Avatar
i pour it down the sewage drain?
Old 08-16-08, 10:27 AM
habeeb89
habeeb89's Avatar
Yep, take it to Autozone, they take it no questions asked.
Old 08-17-08, 05:40 AM
Spyder78
Spyder78's Avatar
I use a sealable oild drain can that autozone sells $10 no problems and no mess.
Old 08-18-08, 06:52 PM
MEANDAFAKA
MEANDAFAKA's Avatar
what about dig a hole in your back yard, and pour it inside?
Old 08-18-08, 10:08 PM
raytseng
raytseng's Avatar
+1 on the oil drainpan with lid. It's not expensive, and using the proper tools for the jobpays for itself in saved time. Getting oil back into bottles is extra step both in time cleanup.
If you really are that cheap, I've seen people drop off using half-gallon widemouth screwtop emptied bottled-water bottles, remember to take back your empties for the next change.
If people are seriously dumping your oil, you should turn in your wrenches and give up on self-maintenance. Oil change is the most basic maintence procedure, and if you are not disposing of the oil at the properly, you have not completed your oil change.
http://www.recycleoil.org/
Quick Reply: what do you do with your old oil after you change it yourself?
