1st Oil Change - Used 1998 GS400
Old 12-18-07, 04:26 PM
werewolf
werewolf's Avatar
Default 1st Oil Change - Used 1998 GS400
Hi
I am changing the oil on a recent purchase of mine, a used 1998 GS400 with 114K miles.
I don't know if the previous owners used synthetic or dino oil, so I am thinking of running a syntho-blend of 5w30 just in case.
What do you think? Which brands do you recommend or would avoid?
The local shop wants to use Quaker State blend for the service...
Thanks
Old 12-18-07, 04:52 PM
Teal Sc400
Teal Sc400's Avatar
Default Synthetic Oil
werewolf, Mobil 1 Extended Performance 5W-30 or Mobil 1 5W-30 and put in a Mobil 1 Extended Performance oil filter too.
http://www.mobiloil.com/USA-English/...Oils/Oils.aspx
Old 12-18-07, 05:55 PM
Rollin'ES3
Rollin'ES3's Avatar
Whats the difference between the Extended Performance from Mobil 1 5w-30, and just the regular Mobil 1 5w-30?
The price is always a dollar or so higher on the Extended Per. Does anyone know whats in it? Ive never read the back to figure it out.
Old 12-18-07, 06:24 PM
Shawnmack
Shawnmack's Avatar
Mobil 1 ext. says you can go up 15k before your next oil change.
Old 12-18-07, 09:36 PM
Rollin'ES3
Rollin'ES3's Avatar
I know that but I was wondering whats the difference between them both.
They are both FULLY synthetic. I was wondering more along the lines of ingredients. Just curious as I always am If any oil freaks know.
Old 12-18-07, 11:22 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Its probably just a more complex additive package. Amsoil has had synthetic oil that can go 10k+ miles for a long time. I personally would never go that long. Im a 5k mile oil change guy.
I would just stick to regular Mobil 1 5w30 if you want synthetic. I use regular 5w30. My car has 172k miles on it and counting, with no engine problems.
Old 12-19-07, 08:41 AM
GSteg
GSteg's Avatar
In addition, I wouldn't leave an oil filter in that long anyways. I guess you can change the filter at 5k miles or something, and then top off the oil, but then again, why not just do a full change since you're there anyways
Old 12-19-07, 09:21 AM
Rollin'ES3
Rollin'ES3's Avatar
Cant argue there. I'm so paranoid I change mine out every 4.5k
Old 12-19-07, 09:28 AM
GSteg
GSteg's Avatar
<---1.5k mlies here
dont ask
Old 12-19-07, 09:31 AM
RI-Lex
RI-Lex's Avatar
im doing mine tomorrow, i use mobil 5000 regular blend 5w-30, but usually change before 4k anyways
Old 12-21-07, 01:38 AM
Rollin'ES3
Rollin'ES3's Avatar
Originally Posted by GSteg
<---1.5k mlies here
dont ask
Sorry but I must.......why
What type of oil do you use? What kind of conditions do you drive through?
Old 12-21-07, 01:46 PM
sonyman
sonyman's Avatar
Wrong. Neither is fully synthetic. Mobil 1 contains at least some group III base stocks, which are NOT synthetic. Synthetics are group IV and V basestocks. As far as group III oils are concerned, Pennzoil Platinum is currently one of best on the market. For a true synthetic (group IV), Amsoil is king.
Old 01-11-08, 01:41 AM
dung0981
dung0981's Avatar
3k for mobil 1
Old 01-11-08, 09:49 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Mobil 1 here as well... tried Royal Purple, and noticed a little more top end noise than with the Mobil 1... Going to switch back...
Mobil 1 may be partially group 3, but it is still an excellent oil that is definitely more readily available than most others...
Old 01-11-08, 10:35 AM
kit cat
kit cat's Avatar
15k? Even if Mobil1 recommends that, that'll scare me.
Quick Reply: 1st Oil Change - Used 1998 GS400
