View Poll Results: Best Fuel Injection Cleaner
STP
19
13.87%
Lucas
42
30.66%
Gumout
6.57%
Other
67
48.91%
Voters: 137. You may not vote on this poll
Fuel Injector Cleaner.
Old 06-25-07, 02:37 PM
animefreak
animefreak's Avatar
Default Fuel Injector Cleaner.
I was always taught that there is no such thing has a Mechanic in a bottle for car treatments. But I was never to sure on carb and injection cleaners. So my question is do they really work? Which is the best? Do they do more harm than good?
Old 06-25-07, 04:26 PM
TunedRX300
TunedRX300's Avatar
If you believe additives that oil companies put into the gasoline works. Yes.
Because some over the counter have the same additives just in higher concentration.
Be very careful not to make a blanket statement that Brand X works because almost all brands offer different products. For example, Gumout Regane Complete Fuel System Cleaner has 30-40% Polyether Amine. The less expensive Gumout Concentrated Fuel Injector Cleaner has less % of the good stuff.
BTW, PEA is also a major additives that make Chevron Techron gasoline effective. Go to BITOG if you wish to find out more.
Old 06-25-07, 04:28 PM
E-Z ES300
E-Z ES300's Avatar
Chevron w/ Techron IS THE WAY TO GO!!!
Old 06-25-07, 04:40 PM
VVT-i
VVT-i's Avatar
BG 44K is the best cleaner out there, but it's expensive and you can't buy them at your local auto parts store.
Old 06-25-07, 05:28 PM
MrG4Life
MrG4Life's Avatar
Hmmm, never seen or heard of that brand. I've used Chevron w/ Techron as well as Lucas. I only used a fuel cleaner and treatment once with my GS and that was when I first got the car.
Old 06-25-07, 06:00 PM
TunedRX300
TunedRX300's Avatar
As VVT-i mentioned it is very expensive ~ $23.5 per can and bought at very few places such as dealers.
It is very concentrated stuff and works well, but if one does not have carbon related problem. There are cheaper and more widely avaliable preventative maintenance additives on the market that have decent results.
Here is a discussion thread on BIOTG on BG 44K
http://theoildrop.server101.com/foru...&Number=894906
Old 06-26-07, 08:55 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Valvoline works great. I have used Chevron cleaner in the past with success as well.
Old 06-26-07, 09:49 PM
audi2nr
audi2nr's Avatar
we use it at work, they have a fuel injector cleaner which u run through the injectors without gas, meaning u disable the fuel pump and have this tool that supplies the engine with the cleaner. We also use the intake system cleaner, which also works good, the intake cleaner gets rid of all the build up inside the plenum and off the throttle plate. the intake cleaner gets sprayed after the maf, and after the turbos, using a small nozzle. gotta change oil and plugs after running this stuff through, the plugs get pretty fouled and the oil breaks down.
Old 07-03-07, 06:41 AM
gsproject
gsproject's Avatar
I think lucas is the best when you just need a regular injector cleaner and use it more often. But if you need a powerful one tand have a carbon problem hen get the bk44
Old 07-03-07, 09:56 AM
kingofire
kingofire's Avatar
I have used Redline SI-1 every 5,000 miles and have looked at injectors after 100,000 miles of use and am very impressed with how clean they are and little or no pressure loss. I have never used Chevron with Techron but they seem to have a very good word of mouth with my mechanic friends.
Old 07-07-07, 01:12 PM
GSquicksilver
GSquicksilver's Avatar
Lubro Molly "Jectron"
German stuff, it's awesome.
Old 07-07-07, 03:17 PM
Lexmex
Super Moderator
Lexmex's Avatar
I have heard that stuff is good. A few guys down here, Liqui Moly is big in Mexico, swear by this stuff, but I have yet to give it a try.
Old 07-10-07, 01:12 PM
TunedRX300
TunedRX300's Avatar
I found a MSDS on BG 44K, a little bit dated but in 1997 it has some common solvants as other cheaper additives sold in stores.
Product Number: 208 AI1 Sizes
Product Name: 44K@
Product Use: Fuel additive
CAS Number: Not Applicable
COMPONENT Percent
Light Aromatic Solvent Naphtha (N/A)
1, 2, 4-Trimethylbenzene (10-15%)
Xylene (0-5%)
Cumene (0-5%)
http://www.dcs.state.ok.us/SW_Contra...chment%20M.pdf
Two of the major components are shared with STP Complete Fuel System Cleaner, just in higher concentration.
Chemical Percent
Naphthalene (21-42%)
1,2,4-Trimethylbenzene (3-8%)
Kerosine, petroleum, hydrodesulfurized (60-80%)
http://householdproducts.nlm.nih.gov...nds&id=3027052
If you buy 2-3 of STP Complete Fuel System Cleaner and dump into your tank, essentially you get BG 44K (ok, formulation as of 1997)'s main solvants in right composition and concentration.
Old 07-10-07, 04:37 PM
sonyman
sonyman's Avatar
BG 44K, hands down.
Old 07-26-07, 11:26 PM
TRD_Power
TRD_Power's Avatar
Originally Posted by sonyman
BG 44K, hands down.
I beg to differ... I used it and it did NOTHING. Use Liqui Moly, I did and it made a huge difference
Quick Reply: Fuel Injector Cleaner.
