Engine stalls when decelerating
Old 01-17-07, 06:22 PM
Herm
Herm's Avatar
Question Engine stalls when decelerating
1993 LS400 137,000 miles. Over the last two weeks I have had two occurances of engine stall while slowing for a traffic light, foot off accelerator, gentle braking. Starts right up after stall. No trouble over the last few years. I do all of my own work, kept up with maintenance. Idle speed looks good, otherwise starts and runs great. Would appreciate any thoughts. Thanks - Herm
Old 01-18-07, 04:33 AM
sliva001
sliva001's Avatar
I have the same problem. Do you have a CEL?
Old 02-10-07, 07:07 PM
amul
amul's Avatar
Could be a lot of things........
Have you had problems with idle, or acceleration?
Could possibly be the MAF? or MAP? not sure what in the intake on that car.
Try cleaning the MAF sensor with rubbing alcohol .
Old 02-10-07, 10:09 PM
narfy
narfy's Avatar
i'm pretty sure you have a vacuum leak, where symptoms are magnified by sloppy, worn out engine mounts... it sounds to me like your vacuum leak (probably the pipe between the air flow meter and throttle body) is cracked...
easy way to test is to let your car idle, open the hood, and grab that hose and squeeze it firmly (don't crush it) and see if your rpms change... if it does, replace the hose first... and then have your engine mounts checked...
hth
Old 02-11-07, 12:27 PM
bizzy928
bizzy928's Avatar
Had a similar problem with our RX.
One of the idle air control valves needed replacing. And also the battery...
After we fixed those two items, no more stalling.
khutch
Performance & Maintenance
43
11-28-13 01:05 PM
yuyo
Maintenance
02-21-11 08:33 PM
sherwoodjb
01-26-11 07:43 PM
lexdud
13
12-29-09 09:25 AM
ScNoobie
04-28-09 09:46 AM
Quick Reply: Engine stalls when decelerating
