View Poll Results: Would you get K&N air filter?
Voters: 328. You may not vote on this poll
K&N Air filter: worth it?
#31
lol yeah its pretty outrageous alright
i ordered a FRAM from my local auto parts store last night and they got one in for me this morning
picked it up for $24 USD lol
the FRAM filter has the exact construction as the toyota filter
in fact, i was wondering if someone put the OEM into the FRAM box when i first saw it
lol
same colour of plastic, same amount of pleats and same thickness in paper
OEM is Denso Made in Japan
FRAM is made in Korea
for $24 with the quality of OEM, i couldnt be happier
until im fully convinced to go with K&N if the engine life reduction claim is busted
lol
#32
Lol yeah, FRAM is a good choice for an OEM quality filter, possibly as close to OEM as you can get with an aftermarket brand I believe. K&N has been in business for a long time and actually produce products that are supposed to increase engine life and well-being. I trust that my filter does it's job and so far so good for me. Hope you get what you want man, this is a good discussion and I've learned some already.
-tc
-tc
#34
the filteration can be increased while keeping the air flow same or higher by having a filter of larger filter surface area. They do this by having more filter material.
#36
I don't see the benefit of using anything other then Lexus OEM filters and parts. With normal maintaince your Lexus will last hundreds of thousands of miles using Lexus/Toyota OEM parts. When you buy a vehicle that costs close to $70K it's not worth trying to sort though the hype to save a couple of $$ on a filter and I'm not the kind of owner that plans on keeping a vehicle long enough that "IF" the hype was even true getting 350K miles using X product versus getting 340K using OEM is worth the sweat. Your also never going to feel any performance difference using a K&N filter versus the OEM filter. The only alternative from Lexus recommended maintance might be after the warranty is up going with synthetic oil for extended OCI's using used oil analysis. Might save some $$$ and less time spent changing oil. JMHO
#37
I tested out K&N this summer on a 2000+ mile road trip. Drove my wifes new for explorer from boston to chicago and averaged 16-17 mpg. Installed a K&N air filter while in chicago, drove back home (same trip, same speed) and got 19-20 mpg. That was proof enough for me... worth the few extra bucks.
Have since found out that AMSOil is making high flow air filters that are supposed to be even better.
#38
#39
You and I may be LX470 owners but they're not. So only the LS and LX can cost up to 70k+So enough with the bragging
#41
Here's a site where the K&N filter is compared to several others.
www.bobistheoilguy.com (Thanks to Max707 for the site).
The bottom line from his tests was that the oil-based filters offer minimal increased air flow (increased air flow is good) and definite decreased filtration (this is bad) compared to an OEM paper filter.
#42
I have have no prolbems with the drop in filter in my SC 300. I have seen a K&N intake system burn up mass air flow meters on toyotas. When GST (The Toyota supplyer for the TX,Ok,AR,LA and MS area) started selling K&N intake systems we installed them on a Tundra and Sequoia. Inside of 2 weeks the mass was burned up. Tried EVERYTHING that GST and K&N told us to do. Same thing. Replaced K&N with AEM. No prolbems. I dont know.
#44
AEM is dry-type of filter where as the K&N is oil-typed. I'm not a fan of oil, but I'm using K&N panel filter on my car right now and I have no complaints. I clean the mass flow sensor once every 3 weeks though. I gained 2mpg with the K&N though.
#45
Just take a look at most factory installed tires, they are cheap ones to get you out of dealers' door.
