Temp or Permanent Type IV in stearing pump
I had a situation where among the fluids at hand was Toyota Type IV ATF and PS reservoir was low.
Any one forsees a problem with using Toyota type IV instead of reccomended Dexron II ATF?
Also any issues with coexistance of Dexron II and Toyota type IV in PSP.
Vehicle '95 SC400.
Salim
Vehicle '95 SC400.
Salim
Toyota Type IV, unused, was left over from trans drain and fill.
For Dexron II, I would have had to go buy a quart.
Salim
Salim
i bought a case of type IV atf in march 04 and still have a few quarts left. i've used it in my ps system with no adverse effects, considering it cost me about $3.50/quart back then and the cheapest generic dexron III i can find now costs about $2.99/quart. no harm done and saves a trip to the store just for a quart of atf.
TSB are only issued if the "Normal" process is not adequate.
If DexII was underperfoming (can't think of the right word). You would see a TSB. Extra improvement is the owners choice. ex synthetic vs non-synthetic oil. Note in my situation, that was the only choice at hand.
I would have not asked if I had used DexIV (fictititious), but ppl have cautioned that Toyota Type IV atf is different. My major concern has been about co-existance.
Thank you all who contributed. I will post, if there are problems encountered down the road. [the most reassuring post was ... GS4 reccomends Toyota Type IV atf for psp].
Salim
Salim
OK i just check again. my cap says use dexron type II or just dexron. The thing is, i've been using type T-IV for awhile now and i haven't ran into any problem.. Then again, i only put a couple of ounce in so I doubt that'll do damage.
It's probably better to go with the regular toyota ATF (dexron) though.
Toyota has in fact issued a TSIB regarding the fact that T IV can be used to replace Dx II/III. However, it doesn't work the other way around, i.e Dex III can be used to replace T IV application. No issue at all with using it in the PS system.
colenzae
RX - 1st Gen (1999-2003)
12
12-01-10 12:12 AM
