Picture of LS430 drain plug
Strange question, but can someone post a picture of the LS430 oil drain plug? I have a 2002 LS430, and I'm getting the things together to change the oil. I want to make certain I don't drain the transmission fluid instead, which I understand is a common mistake.
Thanks!
Sean
Thanks!
Sean
There's absolutely no way to mistake them unless you have never seen a RWD car underneath. The tranny is BEHIND the engine; once under there, it'll be obvious. Engine oil drain plug is by the front tires, whereas the tranny drain plug is by the shifter. You'll have to remove the belly pan to remove the oil filter without making a royal mess. And you'll need ramps for that.
I'd advice you to find a buddy with experience and help you do it your first time. Good luck.
