Help on LS430
Help on LS430
If I take off the wheels, hold the studs, and try to move clock wise and counter clock wise, I can move it a tiny bit. I could also hear some kind of metal to metal noise. Do you know what is wrong and is it easy to fix it? This seems to only happen to the front.
Keep an eye for the "normal" brake pad wear and brake dust. Look for a discoloration of the disk. comparing the fronts to the rear disks.
What you discribe may be a little air in the brake lines and not allowing the hydraulic action of the master cylinder suck back the pads from the disks. Instead, the air compresses the brake fluid and causes the pads to drag on the disk.
Is the brake fluid fresh?
