How to Reset : " Main. Req. "
Old 07-01-05, 08:04 AM
OGS
OGS's Avatar
Default How to Reset : " Main. Req. "
All,
well I got a oil change this morning...but the Main. Req. light is still on (the red ! in the middle of the RPM cluster), does anyone know how to turn this light and warning off?
Or is it because of the BBK kit and the brake sensor, cause this is also now on......
Old 07-01-05, 10:50 AM
steviej
steviej's Avatar
Try this.
1. get in car, shut doors. put key in ignition and do not move it.
2. make sure your odometer is on total miles and not trip A or trip B. If it is not on total, then push the button right next to it to scroll through trips A and B and back to the total miles.
3. now take you finger off the button and wait a second.
4. With your left hand push that button in and hold it, DO NOT take you finger off it.
5. With your right hand turn the key to the ON position. DO NOT START the car.
6. Keep your finger on the button until the maint. reminder light flashes at you or goes out.
7. Turn the key back to off.
8. Take your finger off the button.
Now start the car normally, the maint. reminder light should be out.
If it doesn't work, repeat the procedure and reverse steps 7 and 8.
steviej
Old 07-01-05, 11:47 AM
OGS
OGS's Avatar
Thanks!!!
that worked for the Main. Req......but still have the "brake wear"...
Old 07-05-05, 06:10 PM
Jeff@Longo
Jeff@Longo's Avatar
Originally Posted by OGS
Thanks!!!
The brake sensor is a wiring kit that's replaced (if excessively worn) when the brakes are replaced. Seeing that you have the BBK, you may want to find a way to disable the light. It's just an annoyance to you at this point. The best way is to just remove the bulb.
Old 07-11-05, 09:23 PM
koolaidman
koolaidman's Avatar
heres a better way
remove the connector to the brake sensor
jump the wire
lexus elec brake sensors are a closes circuit when it becomes open it signals the brake light to be turned on
Old 07-21-05, 11:49 PM
playboi
playboi's Avatar
anyone figure how to reset this stupid light?
Old 07-22-05, 08:56 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
What year vehicle do you have and model?
The directions were pretty clear above, if you want more reference check these links:
https://www.clublexus.com/forums/sho...d.php?t=125357
https://www.clublexus.com/forums/sho...d.php?t=123825
https://www.clublexus.com/forums/sho...d.php?t=109931
Bubble
08-31-15 07:43 PM
andy595
GX - 1st Gen (2004-2009)
10-26-11 09:42 AM
Weighit
Hybrid Technology
07-27-11 08:44 AM
bigolow
06-23-11 07:04 PM
gs4bkny
11-29-10 06:30 PM
Quick Reply: How to Reset : " Main. Req. "
