Gas smell in my '92 SC400
Just bought a '92 Lexus SC 400 (185k miles) from my father-in-law. Before he sold it to me he had some work done on it. One of the things he had two different mechanics look into was a gas smell inside the car. Neither mechanic could figure out how or why it was happening.
It's real noticeable when you get in it after it's been sitting overnight. It persists if you don't set the A/C to "fresh air" and leave it on "circulate". Once you set it to fresh-air, it's basically gone within a minute (although it kind of still lingers in your nose).
The prime suspect for both mechanics was the fuel pump and bothe confirmed that it wasn't the culprit.
Anyone else experience this in their "older" Lexus and figure out what was causing it?
Wanted to give this a "bump" and provide a little more info.
There's another problem with the car that might be related to the gas smell. It seems to have problems starting mainly after short trips. Starts fine after it's been parked for a while. But if I drive a few minutes, run into the store (or whatever I'm doing), when I get in and try to start it up, it seems to have trouble. It turns over, but stalls out quickly. I wait 30 seconds, try it again, if it happens again...i wait a minute. That usually does the trick. Thought it might be related to the gas smell. But if it was an interruption or leak in the line, you'd think the mechanic would have figured that out pretty easily??
