Transmission Flush-frightening results
I had a complete transmission flush done on my '99 GS4 with 72k today and the fluid was completely black. They had to run 19 quarts through the BG machine until the fluid was that nice strawberry red color of new fluid. I have done the partial replacement by draining what is in the pan every 15k since I got the car as suggested by the dealer.
I don't notice any difference in how the car shifts or feels after the flush, but am worried that I have not been diligent enough by not having done the complete flush sooner. I see that many CL members advocate the partial drain method, but have to say after what see in my sample bottle that it hasn't been enough for me. I cringe at the scary sample of my fluid and plan to send it off to Blackstone labs for analysis.
Is this the sort of thing that would indicate tranny damage? The car shifts fine now, but did before the flush as well.
if you are reall concerned you might want to pull down the pan
and see if there is any metal in there
there is going to be a little bit
there are 3 magnets in there
and if you can get one change the transfilter also
Did you clean the filter mesh screen & have a new tranny pan gasket installed?
What is the recommended type of tranny fluid your car requires? (IE: Toyota type IV or Dexron III)?
What does your owners manual say as the original recommended interval?
I read some previous threads recommending that a flush not be performed if the transmission has not been maintained, as the sudden introduction of fresh ATF fluid could dislodge some debris and foul up the mechanism. I have a 98 GS4 with about 92K miles and the fluid was changed once every 30K. When I checked the ATF fluid at 90K, it was a dark brown color. After 3 ATF drain-and-fills over 2000 miles, the fluid is back to a normal red color.
When the mechanic dropped the pan on my car, I didn't see a mesh screen... where is it located?
Screen remains with the tranny, not the pan...
Be sure to let us know what the Blackstone analysis says.
I had a new screen filter installed at 60k along with the 4 quart "transmission service". By my reckoning, given that the transmission capacity is 8.8 quarts, I've already changed most all of the fluid by doing 4 quart changes at 15k, 30k, 45k and 60k, PRIOR to this complete change of fluid at 72k. I'm just surprised that having followed the mfr.'s recommendation for service in changing the fluid, that the fluid would be so disgusting looking. I don't have a picture of the fluid, but have always used the Toyota T4 fluid, never anything aftermarket.
Could all this be because of what is in the torque converter that never gets changed out with the regular "drain what is in the pan" method?
Yeah, I found out the screen filter was reusable AFTER I bought a new one online, so figured I may as well have it installed.
Would like to hear more on it if anyone has any other thoughts concerning this.
Peace,
Jonny
It appears that your tranny is fine for now. Make sure that the shop used the right Toyota fluid. Had they used the wrong fluid, you won't notice any problem until 30K miles later. For that reasons, some rough shops use the cheap Mercon (Ford) tranny fluid for any car that comes into the shop. Every car maker has its own requirement for tranny fluid viscosity and friction characteristics.
Good luck and hope nothing is wrong with the car.
Originally Posted by HarrierAWD
While tranny fluid is supposed to last the life of the vehicle under normal condition, it should be checked at least on a monthly basis.
Originally Posted by kreativ
The normal service schedule in the owner's manual of my LS400 does indeed have no mention of ATF change. It only appears in the severe service schedule.
