Transmission Flush-frightening results
Originally Posted by Dx3
I have read this several times but it is a split theory. Some people have never had a full flush, then flushed and then started having tranny problems. I am guessing if you have never done one and then at 120k you do the first, this could cause a problem.
Would like to hear more on it if anyone has any other thoughts concerning this.
Peace,
Jonny
Peace,
Jonny
3UZ-FEEEE
Originally Posted by HarrierAWD
While tranny fluid is supposed to last the life of the vehicle under normal condition, it should be checked at least on a monthly basis.
My car was driven by only ONE owner before me, an older gentlemen in his 60's, and when I drained and refilled a few times when I first acquired the car, my tranny felt much smoother when shifting (he preformed full dealer service per manual and then some). My car doesn’t have many miles either comparing to the other LS owners, so I’m not sure what you mean by the vehicle life. Is that 100K? 200K? 300K?
I think a drain and refill is a must every 30K, I do it more often, but I’m in a lot of stop and go traffic daily. Unfortunately many of us are not able to exercise normal driving condition during our daily commute (but I wish I did).
Originally Posted by GRAND_LS 4
I must respectfully disagree. Normal driving condition would probably consist of light country driving. Because I know for a fact that my tranny gets its fair share of abuse in my daily stop and go traffic during rush hour.
The Toyota spec ATF appears to break down, using some sacrificial element, or chemical as a friction modifyer. Other automatics don't seem to do this, and I've never had a tranny behave like the one in my SC, I suppose it could help the trans to last longer if the fluid is regularily maintained.
Believe it or not, tranny fluid isn't working the hardest in stop-n-go traffic. It's the long high-speed highway trips that could overheat the tranny, provided that the cooling system isn't working properly. Tranny fluid can deteriorate when it experiences temperature beyond its design limit.
Black fluid means something's wrong with the tranny or cooling system *and* the owner does not check the fluid regularly. The tranny fluid need not be changed under normal condition. If you have any doubt, check the owner's manual or the tranny dipstick.
And yes, it feels great driving on Colorado country roads.....
en11871
27
03-17-08 09:56 PM
