Anyone try Valvoline SynPower fully synthetic oil?
Old 03-08-05, 10:16 AM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Default Anyone try Valvoline SynPower fully synthetic oil?
Hey guys,
While at HIN, they gave away coupons for 2 free quarts of the new Valvoline SynPower oil with the purchase of 4. It's pretty tempting, but could this stuff be better than Mobil 1 or is it pretty much the same. thanks guys!
-bryan
Wald GS is offline
Old 03-08-05, 11:18 AM
mburnickas
mburnickas's Avatar
Originally Posted by LexAristo
Hey guys,
-bryan
It is a group 3+ oil I call it. It has 60% group 4 and the rest is group 3. If you are doing short drains it would be fine.
mburnickas is offline
Old 03-08-05, 06:23 PM
saber
saber's Avatar
According to the Toyota engineers, type of oil (synthetic vs. natural oil) used does not determine engine life http://www.saber.net/~monarch/faq.jpg There are many other factors that determine engine life. Example: if the fins of your radiator and air conditioning condenser look like this; http://www.saber.net/~monarch/radjunk.jpg engine life will be reduced because cooling and air conditioning system efficiency will be impaired causing elevated engine temperatures.
The commercial interests that promote the use of synthetic oil never tell the public about things like this and which cause Toyota engines to prematurely end up in the junkyard. Why? Because the commercial interests are only interested in making a sale of synthetic oil because its highly profitable.
Another reason the commercial interests will never tell you about engine life destroyers like this http://www.saber.net/~monarch/radjunk.jpg is because the solution does not involve any special cleaner, lube or filter. The solution involves just removing the radiator and hosing the bugs and dirt off with plain water.
saber is offline
Old 03-08-05, 06:44 PM
PERRYinLA
PERRYinLA's Avatar
Default Time for a high colonic!
This is way off topic, I know, but that is one dirty radiator! Where did that come from, a car that followed an uncovered dump truck full of leaves cross-country?
PERRYinLA is offline
Old 03-08-05, 09:38 PM
saber
saber's Avatar
Perry, the car was a '91 LS400 with only 101,000 miles and owned by a rich middle aged Danville, California couple that used the car mainly for trips to their vacation homes in Shell Beach and Lake Tahoe, Caliif. The car had never been off road, was always garaged and the engine compartment and underbody looked almost showroom new.
Thanks to Toyota Long Life antifreeze, the inside of the radiator looked brand new. Just the exterior fins of the radiator collected alot of leaves, bugs and dust from travel on ordinary California highways (just as an engine air filter does)
saber is offline
Old 03-08-05, 09:43 PM
RA40
Super Moderator
RA40's Avatar
Send a fresh sample in for analysis. Do a fill and drive it for 7,500 or 5k, send that in for analysis then let us know.
RA40 is offline
Old 03-08-05, 10:11 PM
Lexusfreak
Lexusfreak's Avatar
Cool
Agreed.....
Lexusfreak is offline
Old 03-09-05, 09:15 AM
damon
damon's Avatar
That looks suspiciously like a water line as the result of flooding.
Clean those coils by all means!!
http://www.bbjenviro.com/products_powercoil.asp
nomad
PS: Cleaning coils would obviously help AC function as well.
damon is offline
Old 03-09-05, 09:31 AM
PERRYinLA
PERRYinLA's Avatar
Default I'm sure it was cleaned the day he got it
Telling Saber to clean/maintain his own car is like telling the pope to pray.
Old 03-09-05, 01:48 PM
HarrierAWD
HarrierAWD's Avatar
That radiator looks like it's pulled from a trout sale car.
HarrierAWD is offline
Old 03-10-05, 01:15 AM
LS4Lexus
LS4Lexus's Avatar
60% group 4? Isn't Synpower (SL/SM) strictly a group 3 synthetic?
LS4Lexus is offline
Old 03-10-05, 01:21 AM
LS4Lexus
LS4Lexus's Avatar
I'd be interested in hearing the Toyota engineers' explanation on why you shouldn't switch back to petroleum-based oil after using synthetic in Toyota engines.
The myth that you can't switch back to dino after using synthetic has been debunked for some time. The oil manufacturers, the ones that would rather you stick with the $$$ synthetic, also say it's not an issue.
This seems to me like outdated information that never got removed - the bit about having to stick with synthetic after switching to it is noticeably absent from Lexus' version of the FAQ entry. But if this is the Toyota engineering dept.'s current stance, I'd certainly like to have them elaborate on it.
LS4Lexus is offline
Old 03-10-05, 05:01 AM
mburnickas
mburnickas's Avatar
It is a group 3 technically but has some other adds in. It conforms to MB229.3, ACEA A3 spec's.
There Valvoline VR-1 is a group 2 oil.
I just looked at the MSDSs for Synpower and the 20w50 is PAO!
The 30 weights are Group III:
5w30: CAS 64742-54-7 (52-62%)
10w30: CAS 64742-54-7 (53-63%)
But look at the 20w50 MSDS:
20w50: CAS 68037-01-4 (65-75%). MolaKule just had a thread on CAS numbers showing this one to be PAO. I wonder if PAO is cheaper in the larger size molecules of a 20w50?
I also think there 5w-40 is a group 4/PAO. Both PAO oils are low in zinc and phosphorus.
Old 03-10-05, 05:57 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
And who said you have to wait till your first oil change to use Synthetic? Some cars come from the Factory with Mobil 1. These myths were long disputed.
GRAND_LS 4 is offline
Old 03-10-05, 07:16 AM
Lexusfreak
Lexusfreak's Avatar
Cool
Agreed Grand.
Quick Reply: Anyone try Valvoline SynPower fully synthetic oil?
