GX470 Front Bearing Maintenance
Old 03-07-05, 09:03 AM
mikesitsch
mikesitsch's Avatar
Question GX470 Front Bearing Maintenance
There is a 2 year/30,000 mile maintenance requirement for the front wheel hub of my GX470. One item requires re-greasing the bearings. Review of the maintenance manual for the car indicates the bearings are sealed units and pressed onto the hub. It does not appear the bearings can be re-greased. Also, it appears the splines on the CV joint shaft should be re-greased. Since the front hub is sealed I'm not sure how necessary this maintenance item is. Any clarification as to the necessity of these maintenance items and specifically how to perform is is much appreciated!
Old 03-07-05, 03:16 PM
VVT-i
VVT-i's Avatar
Welcome to CL. Yes, the front wheel bearing on the GX is non-serviceable with sealed type bearing like those on ES, GS, IS, RX, LS and SC. Just ignore the mis-printed in the manaul that was original in Japanese and then translated to Jing-lish.
Old 03-08-05, 04:06 AM
mikesitsch
mikesitsch's Avatar
Smile Thanks!
I really appreciate you taking the time to provide a response. It's very helpful and confirms what I've thought makes sense. Have a great day!
GHo23
GX - 1st Gen (2003-2009)
08-22-16 06:32 PM
river
RX - 1st Gen (1999-2003)
04-03-16 10:03 AM
eddyprice
03-26-10 06:11 PM
r3dl4b3l
10-05-09 09:48 AM
ARISTO 161
Maintenance
12-18-06 02:53 PM
Quick Reply: GX470 Front Bearing Maintenance
