Starter relays?
Old 09-02-04, 08:29 PM
RA40
Super Moderator
RA40's Avatar
Question Starter relays?
The other day when I went to start the car I got nothing. No click, just silence. I returned the key to off then back to start and it kicked over without a problem. The battery is newish at 2 years old. When the starter fires up, it sounds normal and the car fires up immediately.
Could this be a starter relay? Any symptoms to help narrow it down?
Old 09-02-04, 09:05 PM
nthach
nthach's Avatar
check the NSS on the tranny?
Old 09-03-04, 11:34 AM
RA40
Super Moderator
RA40's Avatar
Today it just clicked but repeated turns the engine did turn over. I checked the starter relay...checks fine. Also played with the NSS and it had no effect. I'm going out to have the battery, starter and alt checked now. I pray it isn't a starter.
Old 09-03-04, 11:58 AM
nthach
nthach's Avatar
I wouldn't be the one replacing the starter on a 1UZ. My dad's Cressida had the same symptoms, turned to be the starter, and it was an aftermarket starter, so i had to replace the contacts inside with OEM Toyota ones. Morale of the story: use OEM Toyota or Denso starters or alternators.
Old 09-03-04, 03:35 PM
RA40
Super Moderator
RA40's Avatar
I ran the car by the local Kragen and he hooked up and checked the battery and alternator...checked okay. On the way home I stopped by Lexus and they wanted $91 for a diagnostic fee. With the Labor day weekend, no loaners were vailable so I wound up bringing the car home until I can figure out what I want to possibly pay.
It's a pisser, when this thing has repairs it is the not so common ones and expensive. Come-on...a door lock cylinder for $500 and now possibly a starter at $1K.
As second owner of an '85 Cressida, I had typical maintenance things, A/C, alternator, rack & pinion, PS pump...the rarest was when I sheared a keyway on the crankshaft. None of my Toyotas have had to have a starter replaced.
Old 03-02-05, 04:05 PM
mattolsen
mattolsen's Avatar
I posted this on another starter thread - I've had 3 es300's and 1 toyota van and I had to replace the starter on ALL of them. But I buy 10+ year old cars, you've got to expect something to go. On an es300 going to a regular mechanic, not getting bent-over by the dealer, it's not too bad. Maybe $300.
Old 03-02-05, 05:27 PM
VVT-i
VVT-i's Avatar
But, on RA40's LS400 you have to remove the intake and lower the transmission. Now, the regular mechanic may not want to do this job because the starter on the V-8 is located under the intake manifold. Lexus designed it this way so the starter is away from the exhaust heat( compare to most of the V-8 that put the starter right by the exhaust manifold).
Old 03-03-05, 01:09 PM
RA40
Super Moderator
RA40's Avatar
It is pretty amazing they designed it that way. The one issue is the level of disassebly to make a repair there. I'm guessing they felt starters were such infrequent items of replacement they moved it along witht he heat issue. Dunno...
Fingers crossed for another 80K minimal.
MOAWINGS
08-26-20 04:19 PM
OneJay
Performance & Maintenance
21
08-15-11 03:24 PM
jcastaneda
02-02-11 09:46 AM
SuicidnS13
11-02-10 08:51 AM
b1gredek
10-07-04 08:45 AM
Quick Reply: Starter relays?
