95 ES Differential and Trans fluid change ?
I've done a search but I just want to make sure I've got this right.
When I have the trans and diff fluid drained and refilled-
There are 2 seperate drains for trans and diff I know. Do you refill the diff seperately? I will need 4 quarts toyota dextron 2 fluid right?
thanks
chuckb
thanks
chuckb
On the 95 ES you can fill the trans and diff fluid from the transmission dip stick tube. If you drain both drain plugs( trans and diff) you will need about 3 1/2 qts of Dextron.
CLUM
01-27-15 06:47 PM
Neil4Speed
Performance & Maintenance
08-01-14 05:22 PM
