Timing belt ?
Timing belt ?
I was wondering how hard it would be to change a timing belt on a 95 es 300. Im fairly handy with tools and just recently changed my power steering pump which was hard as hell to do due to the fact there was like no room to work with. So any input on people that have actually done it would be alot of help.
Yes. I drove the LFA.
ES t-belts are some of the easiest to do. If you did a p/s pump, i dont think you will have any problems doing the t-belt. Depending on how experienced you are, it should take long either. I can have an ES t-belt done in about an hour and a half, including cam seals, crank seal, and water pump... Good luck bro, you should be fine!
Jackwillsa
11-06-16 08:53 AM
