Heavy vibration at highway speeds?!
My 97' LX450 vibrates heavily to the point where it's embarassing me in front of my passengers. At first I though i need to rotate the tires. I just had my 30k service and they supposedly rotated the tires, and the problem persisted, could it be that they actually didnt and lied about it? How could I tell if they did? What else could cause this problem, I feel the vibration heavily in the steering wheel and my friend asked me if the car was gonna fall apart driving down the highway to a wrestling meet! Any insight is appreciated, thanks!
Check the balance on the front tires (might as well check all 4) and your alignment. Either could cause vibration in the steering wheel, but if they really did rotate the tires and it's still shaking the your front alignment is suspect. Are the tires wearing unevenly?
Sometimes it can be as simple as tire pressure -- low tire pressure can cause vibration also.
If that's not it start looking for an out-of-round tire or damaged wheel (but that would have given you a shake in the rear that you would feel in the seat of your pants before they rotated the tires).
Frankly, I don't remember what's included in the 30k (or what you had them do). How long ago was it done? Are you sure you paid for an alignment? Did it vibrate before the 30k? If so, did you tell them about it?
If not, you may be sol. They can always say it happened since it they want to be difficult.
Well, if they road tested it and it was vibrating when you picked it up after the road test, that was a good time to mention it. Wonder if they got over 10 mph during the road test...
Look, if they say they did an alignment and the car is vibrating you have a reason to bring it back and tell them that. But since you didn't tell them about the problem beforehand they may dance out of it (the -- "You must have hit a major pothole 10 minutes after you left the shop. That's not our fault." -- excuse). It's worth a try to bring it back and tell them.
So, try the direct approach and tell them they didn't fix the vibration when they did the 30k. In the best of worlds they'll just smile and fix it.
In the future it would help you and the repair shop if you tell them about problems you are having so they know what areas to look more closely at...and you will have more recourse if they don't fix it. Then, after you pick up the car check out what they were supposed to fix and if they didn't tell your service writer about it and if necessary have him ride with you for a test drive so he can see it for himself.
Thanks marty, I appreciate it!
Okay, the said the rotated the tires and checked for alignment in the reicept. Well my cousin, who is a foreign car mechanic, says it's a balance and alignment problem, wasn't that supposed to be taken care of during the 30K?!
Re: Thanks marty, I appreciate it!
mattds
ES - 5th Gen (2007-2012)
07-21-13 06:28 PM
