cooling system stop leaking liquid products?
Old 05-20-04, 04:33 PM
van_es300
van_es300's Avatar
Default cooling system stop leaking liquid products?
Hi, Guys,
I just got a minor water pump leaking problem at this moment. As you know replace it will cost too much for a 92' es300. Then I am thinking about the alertnative way. Did anyone try the "cooling system stop leak products"? It only costs few bucks, but does it really work to help stop the water pump leaking? Somebody said it would be more seriously after treatment. Hope you guys can give me some suggestions. Any opinion is welcome.
Cheers,
Van
Old 05-20-04, 07:09 PM
bob2200
bob2200's Avatar
Default Re: cooling system stop leaking liquid products?
My experience has been with a previous car, not a Lexus. That experience is that stop-leak treatments work best with a small, constant-sized opening. The problem with a waterpump leak, if it is the pump bearings developing play, it that it is going to keep getting worse and the stop-leak treatment will be very temporary. Also, the vibration of the pump shaft will likely keep any good seal from developing. I'd go for a pump replacement.
Old 05-20-04, 09:00 PM
van_es300
van_es300's Avatar
Default Thanks Heaps
Thanks Heaps
Radithor
02-02-19 08:52 AM
Colpup ES3
11-09-07 04:26 PM
Yaj95ES300
09-12-07 09:28 PM
martini53
Performance & Maintenance
05-01-03 03:02 PM
Quick Reply: cooling system stop leaking liquid products?
