How long can my GS300 sit for?
I'm currently half way around the globe on a very long business trip.
My GS300 is parked safely at home in my garage.
How long can my GS safely sit without being started?
Thanks.
Thanks.
My father was in a similar experience with the 7-series when he left it in the garage for an entire winter season a few years ago. When he tried to start it after the winter, it wouldn't start at all. No lights showed up, and we found out later on that the battery was totally drained. We got it over to the dealership and had the battery replaced under warranty.
So my one piece of advice when storing a car for some duration is to disconnect the battery so that it doesn't risk unexpected loss of current.
-Robert
Worse case scenario your battery will be dead if it's a few weeks or even a couple of months. Just charge or replace your battery and you'll be good to go.
If a year or so passes by then your tires will be a few lbs low and have what is called/known as "Out of Round" spots on them (have a flat spot on them from sitting on the concrete for an extended period of time) but I wouldn't worry about it, just replace the tires. Usually people put the car up on jack stands to get the car off the floor to prevent that from happening if it isn't going to be driven for that period of time. Also depends on the climate the car is in since that's a major contributing factor.
Don't worry about and enjoy your business trip if that's even feasible.
This was with my previous GM car from way back. Once I was away for 6 weeks, came back and the car started right up.
As long as the battery was in good condition and fully charged when you left, it'll be alright for a month.
topgun129
07-31-15 08:47 AM
turtle11
08-28-11 07:39 PM
