LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Front parking lights (how to get the the bulb?)
Old 07-20-03, 08:07 AM
wlee69
wlee69's Avatar
Default Front parking lights (how to get the the bulb?)
I'm trying to get to the side parking lights (the ones to the outside of the low beams in the front). How do you replace the bulb in them? Do you have to take the front headlight housing out to access it? If so, does anyone have some instructions on how to take the headlight housing out?
Thanks in advance,
Will
2001 LX470
Old 07-21-03, 01:43 PM
bsjoiner
bsjoiner's Avatar
The corner lights are fairly easy to remove but just take you time and be careful not to break anything our it will be a costly mistake. If you open the hood you will see a screw on each side that holds the lights in. Just remove the screw and then get a flathead screwdriver and insert it between the corner light and the low beam. Gently pry the corner light away from the low beam starting at the wop and working down to the bottom. There is a clip in there that holds the light. You will evently hear a pop and the light will release. If you need more detailed instructions just ask!
icegoffy
05-25-16 10:23 PM
ima do me
02-08-09 12:53 PM
cr00klyn71
07-08-07 08:50 PM
ByoungWoo
11-05-06 06:43 AM
artman
04-25-02 10:45 PM
Quick Reply: Front parking lights (how to get the the bulb?)
