LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
power windows in lexus lx470, 2005
Old 10-26-14, 07:35 AM
rafeet
rafeet's Avatar
Default power windows in lexus lx470, 2005
Hi,
In my lx470 the front passenger power window is not working in auto for up and down , (all other windows work in auto), if I stop pressing the switch the glass stop moving.
I tried to push it in different ways and periods but not working, I tried to do programing buy turning the switch to ON position and press window switch till half then move it up and hold the switch in this position for while but it didn't work.
I noticed that if I disconnecte battery for minutes and connect it again the window will work normal in auto for 2 or 3 presses. Then it will stop doing that.
Please anyone has solution don't hesitate to help.
Thanks
Old 10-26-14, 06:18 PM
cnfowler
cnfowler's Avatar
You could try replacing the faulty switch with one of the other window switches that is known to work. That will let you know if it is the switch or if the problem is somewhere else.
Colin
Old 10-26-14, 11:55 PM
rafeet
rafeet's Avatar
Default power window not working in auto
Thank you for help cnfowler,
but the problem is not defected switch because I can't operate it in auto from main switch also,
It works up and down but if I want to move it full with one press I can't.
as I said before if battery terminals disconnected for minuet it will work for seconds in auto, I can roll it up and down full with one press, but this will be for less than minute, then it will return back to first situation.
all windows will full close if I hold the key while locking the car manually from driver door, but this particular window is not moving at all.
I also noticed the passenger window switch light sometimes blinking and sometimes not working.
Old 10-30-14, 12:31 PM
rafeet
rafeet's Avatar
Default Thanks
Thank you very much guys for the help I got here.
This is the most helpful fourm ever seen....
I hope you you continue in this path.
Cheers
Stereorob
12-11-15 05:47 PM
lexus114
02-09-12 12:44 PM
Woozy
02-24-11 07:37 AM
atlantis43
Maintenance
12-08-10 09:55 PM
super58177
08-25-08 04:01 PM
Quick Reply: power windows in lexus lx470, 2005
