LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Lx 470 A/c is not working
Old 03-10-14, 11:36 AM
keymaker
keymaker's Avatar
Default Lx 470 A/c is not working
Hello ,
My Lx470 2003 , A/C stopped working , and the front panel doesn't control at all except the climate button , when i press it , the Nav screen says , Check the connection of Air conditioner , And i have checked all of the fuses , but i didn't find any thing wrong , so please guys what should i do to fix it .
Old 03-11-14, 03:06 PM
keymaker
keymaker's Avatar
Default ok , Guys
It seems that no one knows what is wrong with my car , anyways I changed the A/c amplifier today , and still have the same problem , so please guys , is here any know where is the A/c relays ? please i really need help in this .
Old 03-12-14, 08:51 AM
kwatt1
kwatt1's Avatar
Do the fan controls work? If the do, the A/C is likely low on Freon. There is a High and low pressure switch. If the Freon is low the switch will prevent the compressor from coming on.
This assumes that the rest of the console is working and you are not having some other kind of issue.
Old 03-12-14, 11:19 AM
keymaker
keymaker's Avatar
Default Thanks for replaying ,
its not about the Freon , because the A/c IS not turning on at all , and the other thing is , When i want to change the blowers from the face to foot , its not working as well , the only button thats working is the climate button
Old 03-12-14, 08:05 PM
kwatt1
kwatt1's Avatar
I have a 2005 so the functions could be different... but... the climate button displays the air output locations, the fan speeds and A/C on/ooff.
Separate A/C and fan and output location. A/C just means the compressor should come on. Fan is air movement and one of the speeds in the the lovering is the output location.
Your saying the climate button displays the options on the screen? but none of the options work?
You should consider the Toyota Tech site. It runs like $10 for use over a few days. It is very detailed and it will give you the diagnostic details you need and the wiring schematic if needed.
Old 03-29-14, 05:40 PM
Bolo42
Bolo42's Avatar
Your Climate control box is DEAD. I just had to change mine out in a 98...
Old 08-03-17, 10:32 AM
mohmandem
mohmandem's Avatar
Default Issue Resolved?
Originally Posted by keymaker
Hello ,
Did you resolve your AC problem? What was the cause and how did you fix it?
Old 08-03-17, 03:01 PM
hankinid
hankinid's Avatar
OP hasn't posted since March, 2014.
Assuming you also have an AC issue, you may want to start a fresh thread.
Waleedjatt
02-03-21 04:05 AM
chucknkris
03-31-18 09:01 PM
Dhatherley
GX - 1st Gen (2004-2009)
11-03-15 04:43 AM
craigco
05-18-10 10:39 PM
spxChrome
05-30-03 01:23 PM
Quick Reply: Lx 470 A/c is not working
