2000 LX470 Radio Wire Harness?
Would this be the same wire harness for the 2000 LC?
To be more specific I am looking for a radio harness that would connect the stock plug and allow me to plug in a after market radio? Reason being the idiot that had it before me installed a after market radio and spliced into the factory plug and duct taped everything together lol the only wires that were spliced into were the antenna and the power anyways I am just going to redo ALL of the wiring and Start with a clean install with the factory plug adapter to a after market radio.
Thanks in advance.
Thanks in advance.
when I did ours 5 or 6 years ago there was no harness for the LX and dont think the LC one works as the audio is different and ours had the NAK system system which LC's don't have.
I simply used this guide for what wire is what and made direct connections. Your previous owner probably did the same but somewhat messier from what it sounds like.
2000 Lexus LX470 Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
LovEnPeaCe
04-28-07 10:04 PM
