LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Differences in the 1996 and 1997 LX450s?
Old 06-15-13, 07:25 PM
Bullelk
Bullelk's Avatar
Default Differences in the 1996 and 1997 LX450s?
Does anyone know that they know the real differences in the only two models of LX450s ???
Old 06-17-13, 07:57 AM
7schulz
7schulz's Avatar
Nothing at all. http://www.sleeoffroad.com/newbie/newbie100.htm
1995-1997
■1996 saw the introduction of the Lexus LX450 Model.
■Exhaust system changed from side by side catalytic converters to in-line converters. The exhaust also routes below the frame rail just behind the catalytic converters to avoid excessive heat on the passenger floor-boards.
■Front grill changed from the word TOYOTA written across the front to the new Toyota symbol.
■Headlight mounts are different from 1991-1994 vs. 1995-1997 and will not interchange.
■Redesigned dash board with airbags as standard equipment.
■Headliner changed to two piece molded units.
■Emission system on engine changes. Changed from a Mass Air Pressure meter to a Mass Air Flow meter. Certain plumbing was also removed.
■Supercharger & Turbo systems available for 1995-1997 models.
■ECU updates and truck became voluntary OBD-II compatible. Fully compatible in 1996 models.
■Wheel Lug nuts change from conical to washer type.
■Airbags become standard
■Automatic transmission changes to the A343F. Some 95's were produced with the A442F. The transmission type is printed on the label on the driver door.
■1997 saw the introduction of the 40th Anniversary editions as well as the Collectors Series.
■1997 the rear swaybar brackets that attach the bar to the frame were changed from a plate side that attached to the side of the frame to a bracket style that attached to the bottom of the frame.
■ABS wires on the front were moved upward and no longer run down the front control arm.
■Radiator is a 2 row aluminum
Lexus LX450 Differences
■Revised Audio System with sub-woofer in the center console.
■Optional factory installed cell phone.
■Softer suspension.
■Body cladding on doors, fenders and tailgate.
■Rear bumper corner pieces are bigger and the rear cross member is coverer with a plastic trim piece. Mud flaps are two-tone colored and not interchangeable with an Toyota
■Auto Climate Control
■Softer leather on seats and additional sound proofing.
GS250
11-21-15 06:11 PM
hwy1isf
IS F (2008-2014)
12-19-11 02:19 PM
Quick Reply: Differences in the 1996 and 1997 LX450s?
