Two HID questions
Two HID questions
I have a 2006 LX470 and I want to install HID's from Xenondepot.
1. Do I need to have the dealer turn off my daytime running lights before I install the HIDs in the low beam projectors?
2. What do the people who have installed HID low beams do about the high beam lights?
Thanks!
Thanks!
No you dont its a simple DIY installation just watch a few videos. The lows and highs/drls are seperate so im probably just going to get tinted bulbs just to match my HID 6k's and if it looks bad then i might just turn off my DRLs.
I have the xenondepot hids in my 06. Left the DRL and high beam stock. Only minor issue was the H1 connector plug was slightly too big to fit the factory harness, need to trim it slightly.
Connector show here:
https://www.clublexus.com/forums/lx4...ml#post4649167
Love the HIDs though, they should come from the factory with them.
daytime running lights are fine unchanged from the factory. Why would you want to change?
as far as high beams you can replace with Xenon bulbs, 9005 with right angle connector, if you want to closer match the color of the HID lights. YOu can get the 9005s with 4300K, 6000K. the HID can be multiple colors. 4300 is typical for many factory HID systems.
@ Drewdogg80,
How easy was the install for the H1's? I hit some snaggs fitting the bulbs into the headlight housing assembly. Seemed to be too big for the opening. So as to not hi-jack this thread, check out my post that's listed in the forum just before this thread. Subject is: "issue installing HID kit" or something similar.
