Pictures of your stereo setup..?
Hopefully no one posted this yet, I couldn't find a good search for it. But if you an aftermarket stereo setup , post your pics. I was looking to get a receiver to replace the nakamichi, any suggestions?
thanks
thanks
steer clear from the pioneer... hey that rhymes. um yeah looks great in your truck ali but a far better unit is the kenwood ddx5120 or the dnx5120 (with nav, what i have) it uses garmin for its nav supplier so its super user friendly and accurate and with year models 2001 and older it can be used with the factory amp which is a huge plus and means you wont lose your factory subwoofer capabilities. look it up on ebay right away! they're $1100 bucks at best buy but on ebay u can find a refurbished one for $400 shipped! maybe even cheaper now!
funny, the reason I got the pioneer is my brother has the kenwood in his SC300 and is not a huge fan but I guess to each his own. This one also works with the factory amps which is how I have it set up and was about $400 shipped. I really like the SD card slot up front and that you can load in many upgrades to the software and change your backgrounds with any loaded images but I assume the kenwood also has these features as they are all basically small PC's now and run on windows CE.
Aftermarket Install for 2K LX470
https://www.clublexus.com/forums/lx4...-lx-world.html
how did you connect the reverse switch, where did you get the pick up from...Since i have to run a camera cable to rear, i thought it would be easier running an extra wire from the rear tail/ reverse light at the same time, or is there a closer one that is easy to get to??
sam12345
12-12-14 10:39 PM
KeysRx300
08-16-09 07:38 AM
