running board courtesy light - changing
i have a 2000 so i dont know how to change the bulb as i dont have lights in mine. But if someone w/ them like jim chow doesnt post up how to fix it by tommorrow at lunch time, ill find out and post for ya. It would be as simple as calling a lexus dealership, i just dont know how to fix it as i dont have the lights....i sure as hell wish i did tho.
I looked under. There are small lenses that shine down on the road when the courtesy lights are on. There is no obviouse way to get inside the light strip area.
I believe there is only one source that feeds the light strip and the down looking lens. I took the lens housing apart hoping that would lead to the bulb, but it seems like the lens is on the end of some kind of light transmition rod (fiber optic, maybe).
From the diagram in the FSM, each light strip (there are 2 per side) is a bulb in itself. Then there are 2 of the look down lights underneath the boards for each side. The light strip fits into some kind of retainer. There are these square-shaped things on the end of each strip that attach (looks like via clips/pins) to the retainer. I'm not sure how to remove the retainer, meaning I don't know if you have to remove the board from the bracket or not. There are 4 support brackets for each board (held on by 2 bolts per bracket). On those of that is a metal support board, then the main board you see from the outside, then the rubber part w/ the Lexus emblem attaches to that. It's not clear how the lights fit in. I would look from the bottom inside to see if the light retainer can be removed. Those bulbs aren't cheap. Wasn't there someone on this board who recently got a dealer quote in the hundreds of $$ to replace a single light?
Thanks for the info Jim. Are you saying that the light strip and look-down light are seperate? If that is the case, I probably have a problem with the electrical connector. Does the FSM have the wiring diagram showing were the connector resides and which wires power the rear right lights?
Thanks
Thanks
Thanks
Thanks
OK, I checked the FSM. The power wire on the left side exits the left kick panel area below A pillar (IIRC, red w/ blue stripe), then goes to a connector then feeds all four lights for the left side running board (2 bar lights, 2 down lights).
