LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Not me!
Old 08-08-06, 12:28 PM
valgs350
valgs350's Avatar
Default Not me!
Hey,
So I got into my LX this morning and tried to start it. It took like 6-8 trys to get it turned over but later in the day it starts like normal. I took it to a local mechanic and he looked at me funny and said " Seems Perfect." Should I replace anything or just wait awhile for the starter to do it again.
The starter was working, but it woudn't start the engine, but it starts fine now. I duno whats going on or what went on!
I searched this before posting, all I know is something with the starter contacts! (Maybe)
Thanks
Old 08-08-06, 02:44 PM
Tammy
Tammy's Avatar
I would suspect the starter if you have a hundred thousand miles or more.
If much less, check to insure the 10mm hold down clamps to the battery poles are snug. Or the battey itself is about to fail.
Old 08-08-06, 04:10 PM
valgs350
valgs350's Avatar
I just reached 100,000 this past weeekend!
The battery is fine, I tested that!
I just don't know why it did it in the morning but didn't do it again.
Thanks
Old 08-08-06, 06:02 PM
aedgington
aedgington's Avatar
My starter had to be replaced at 46K =/
Old 08-08-06, 06:56 PM
ktiger
ktiger's Avatar
Thanks
Mine did the exact same thing at 97000+ miles. I took it to the dealer six times before the mechanic decided to just change the stupid starter. We could never get it to act up at the dealership even though we would leave it there over night. The mechanic began to start feeling sorry for me and recommended changing the starter. The wife have never had a problem since.
Old 08-09-06, 03:04 AM
03LX470
03LX470's Avatar
I recall reading here at it may only be the starter contacts that need to be changed rather than more expensive starter. Do a search of this forum.
Old 08-09-06, 11:15 AM
valgs350
valgs350's Avatar
Thanks
It started fine today, I duno what happened yesterday!
Hopefully it won't start doing it again!
Thanks
Old 08-09-06, 04:00 PM
V8_Fan
V8_Fan's Avatar
If you just here the solenoid "click" and there's plenty of juice in the battery (ie, enough to power the headlights, etc.), it's the starter contacts going bad. They degrade over time. I wonder if the longevity has to do the V8 likely drawing a lot more current through the starter contacts? I'm still on the original contacts on my 86 4runner. I know that starter requires little current to start the little 4-cylinder engine (I used to have a 450 cca battery that did fine).
Old 08-10-06, 10:32 AM
playa3uhh
playa3uhh's Avatar
it's definitely the starter. The same thing happened to me in my 1997 LX450 about a year ago. Sounds like the same symptoms I had. Thought it was the battery, but nope it was the starter. Took it to Tires Plus and haven't had a problem since. Hope this helped! Good Luck
--John
MOAWINGS
08-26-20 04:19 PM
OneJay
Performance & Maintenance
21
08-15-11 03:24 PM
rsr405
07-23-06 08:44 AM
RA40
Maintenance
03-03-05 01:09 PM
Quick Reply: Not me!
