470 Lx Vsc Off
Either a bad sensor...or you accidentally hit the CENTER DIFF LOCK button (most likely culprit). So, try hitting the button again and see if it goes off. Do NOT drive your LX until you have ruled out that your center diff is not locked.
BTW, the "center diff lock" button is the one with four wheels and an "X" in the middle.
Good luck.
Good luck.
I know this has been a long time since the post but this problem just occurred yesterday for me. You're saying to not drive until the lights are gone. However, I did drive it for more than an hour, about 80 miles worth of it. What kind of problems should I be expecting now? The drive is fine, but there is a strong gasoline smell in the interior. I'm not sure if this would have affected it, but it's almost unbearable. Thanks
mansito
GX - 1st Gen (2003-2009)
33
07-06-21 10:50 PM
dbs600
03-17-13 06:44 PM
