2016 LX570 Owners - What are your first impressions?
I am quite happy with 18" wheels from '16 Land Cruiser. They are quite cheap on eBay. Probably many new LC owners want to replace their wheels with some stupid 21" or bigger wheels. Unless you plan doing some really difficult trails (which would also require some lifting, offroad bumpers, rock rails etc.), you would be probably fine with 18" wheels.
EDIT: Found this:
http://pressroom.lexus.com/releases/...specs.download
Front brakes .5" larger in 2016, rear brakes same 13.6".
Wow... Thanks @Hankinid, @Chocolate and @ClaytonW great information. I'm obviously going to need to do a little reading/learning about this but maybe 18" is the way to go.
Just filled up the tank with gas...the dash indicated 43 miles remain. I could only get 16.3 gallons into the 24.6 gallon tank. Notifications seems to be fairly inaccurate, is this normal?
That is normal. Toyota really wants you to keep some extra fuel in your tank. I put in 18.5 gallons when the gauge was showing near empty.
By the way, I only calculate mileage the old fashioned way
The worst example I've seen was a year or so ago when a guy in Japan wanted opinions here on 24" wheels for his wife's LX. You could say he had a strong dislike for most of the answers.
I think I've seen the yellow light once in the LX, not yet in the Land Cruiser. To me, it's meh. If you're not scanning the instruments periodically, you need to re-learn how to drive.
They might clear (.3" larger than rear) but you would probably want to test fit a spare RW wheel to see.
275-70x18 is about as large as you can add without a lift in the front. My AT II's are that size, and I get a tiny amount of rubbing at full lock...if I trim about 1/2" off the bottom of the front mud deflectors, the rubbing will stop and no one would notice the difference.
HanaleiISF
12-05-14 03:47 PM
JASP615
GX - 1st Gen (2004-2009)
09-04-09 05:55 AM
