Tire recommendations
Interested to see what others have chosen for their tires. I recently purchased 18" tundra wheels and am trying to decide on a new set of tires. The suv came with the Michelin Latitude HPs but they were not very effective this past winter. Outside of a dedicated winter set-up, what is everyone using for an all-season or all-terrain tire.
I'd welcome any suggestions, will be 95 - 99% highway.
I'm going down this path too soon, car currently has cooper tyres but theyre old cracked and noisy (still good offroad and a fair chunk of tread though.
I'm personally thinking of going for the general grabber SRL, i love that red writing, should look good on the black car too....
Michelin A/T's seem to last about as long as Toyo's, are oriented imo a bit more toward paved v. unpaved roads. I mounted 3 sets on 3 Suburbans before I saw the light of the LX and had no issues.
I'm getting Toyo's for my truck by the end of the month. Latitude HP's were great on great highways, but a tad scary on washboards and typical Forest Service roads. Price was repulsive and I'm not about to verify her governed top speed of 137 mph.
Only other suggestion is to rotate the tires when you change the oil...If you're running syn at 10K intervals, do the tires around 5-7.5K maximum.
Although I am getting new set of all terrain tires this year on 18's, I will provide this insight:
Currently I am running the stock size Goodyear Eagle IIs and they are slippery when wet or icy, so not good in Winter conditions here in Idaho. They are fairly quiet, but not as quiet as I would expect for something that is very black-top specific. I have had them off-road once and they are a major reason that I am going both to an 18" rim and an all-terrain.
I hope this helps... not that it gives you a straight answer.
I went with duratrac (https://www.clublexus.com/forums/lx-...e-2010-lx.html)
They are excellent in deep now, great on ice - they have the mountain and snowflake symbol. but they are heavier than oem, louder, and rougher. if you need to go to the very aggressive end of the AT spectrum, I would suggest you give them a chance.
I'm looking forward to seeing how they do in the bush / cottage this spring. I'm hesitant on the 20" size but hey we'll see.
If you don't need the capabilities of a DT, choose something else.
J
J
I decided for Michelin LTX AT2 on 18" wheels from '16 Land Cruiser. It's quite comfortable on the highway and good enough for some light offroading.
just as some food for thought, we gave our LX a go on the beach the other evening, it went great with the all terrains that were on it, struggled a touch but they are fairly worn out. also came across some guys running the general SRL that i mentioned above, they couldn't fault their tires, i will definitely be going for a set of them soon!
I love the look of the LX with the new 21 inch wheels, but the tire selection is only Grandtreks which many people on here don't like. Would there be an issue going from 275 50 21 to 275 45 21 on a new LX. In the 45 height there are some more tires available.
The problem is that Discount Tires were not able to program TPMS so I had this done at Lexus for about $60.
I would not do it. At 275/50/21 the rubber height is bare minimum to provide some comfort (not too much) and offroad capabilities are limited to some curbs.
I would go for the 20 inch wheels...I actually don't mind the way they look but my dealer couldn't even locate one on the ground or incoming with 20 inch wheels in the entire northeast region.
Steve
I would call it a major issue. See below.
That's putting it mildly. If anything, I wouldn't go with a larger wheel / smaller tire section choice. I went to 18" tires as I saw ZERO advantage to 20" or larger wheels...higher cost, inability to get a decent tire what would work on a well-paved gravel road, let alone normal forest service road, a much choppier ride compared to a tire with a normal cross-section.
Steve
Steve
